Spec-R R1
#2837
nudge.
If you are at Brendale for Friday racing. I can bring you a front spool with spring steel outdrives and a set of DJC's if you want them. I usually have a few spares as well. I am on my 3rd Spec-R. Where are you planning on racing? also the alu hexs are not wide enough to space the contact rims that most people use here. I am running 6mm locking hexs front and rear I also have 2 spacers on the rear and 1 on the front. Need to find some better offset foams to run on this car.
#2838
I believe that he is wanting the Pro Spec which already includes the aluminum fan Mount and center servo mount.
#2839
The wheel bearings are 5x10x4. The rest of the bearings in the kit should be fine since they aren't under the same loading conditions as the wheel bearings. The xray hard bumper that I bought was the wrong one. ....it was too thick. There is a thinner one that fits. I bought one but haven't installed it yet. I'll find the part number right away.
The kit comes with 5mm aluminum hexes, but I now run 6mm ones and the front wheels still rub the lower arms when turning. 7mm in the front is needed (or 6mm with a 1mm spacer).
You might want to order a pack of 3mm ID and 5mm ID shim washers in 0.1mm, 0.2mm, and*0.3mm thicknesses.
Hi Guys and Girls( if there are any around)
I am looking at buying an R1 ProSpec and was wondering if the following were included or needed to be bought separately.
1: Spec-R ( SPR-R1A110 ) Spec-R R1 Alu. Wheel Hex (4pcs) ( Cant tell be the photos of the car)
2: Spec-R ( SPR-R1H711 ) Spec-R R1 Suspension Mount Spacer Set
3:Spec-R ( SPR-R1H715 ) Spec-R R1 Alu. Belt Stabilizer Mount( Is this really needed?)
Also can someone list the bearing sizes as i have heard they arent that flash in the kit and should be replaced to reduce slop.
Also anything else apart from Front gear diff or DJC's, xray steering hubs, and hard bumper and spare arms and C hubs that i should get straight off the bat when ordering the kit.
Thanks for the help and sorry for the number of questions.
Cheers
Nudge
Cheers
Nudge
#2840
Thanks for the replies.
DBM you are correct. I am going to buy a Pro Spec.
MRJudd thanks for the offer and i will take you up on it eventually. I work away on a 2-2 roster so when i am at home i am going to try to come up and at least have a look on a Friday night( wouldn't mind organising it with you to have a look at your R1.) It wont be this Friday as i am still away but maybe next Friday or the one after. As i live on the South side I will probably mainly race at Bayside as i only live 2 mins from the track and maybe Logan but hopefully on occasions I hope to get up to Brendale as well.
Cheers
Adrian
Cheers
Adrian
#2841
For the S1 I know it doesn't come with the sway bars but does it come with all the mounting hardware and I just need to buy the bars or are there other parts I need to get as well? Just want to have all the parts ready in one order so part numbers would be appreciated. Thanks.
#2842
To solve the front wheels rubbing on the shock I flipped the a-arms and use C hole. The overall feel is much better and gives the car more entry, mid and exit corner speed.
Running wide hexes in front will scrub off too much speed at corner entry.
#2843
The rubbing on my car wasn't coming from the shock, it was from the inside of the wheel contacting the end of the lower arm. Flipping the arm and moving the shock inboard won't fix this, unfortunately.
#2844
I have to run 7mm hexes on the front. You might be able to get away with 6mm. 6.5mm would be best.
#2846
Running on high grip carpet, at full lock, the outside tire rubs on the lower shock mount when using the D-hole.
#2847
I'm using sweep exp premounts. 6mm hex and some sanding of the wheel fixed it. I added ackerman to compensate for the wider front track width.
#2848
Cheers
Adrian
Cheers
Adrian
It is a great idea to get to as many tracks as possible as this will improve your driving. I race at brendale as it is only 5 min away from my place. I haven't been to the southside tracks yet but have been north to Landsborough.
Slowguysam, you do need a couple of other bits to get the sway bars attached. they are
SPR-R1A123 R1 Rod Stopper
SPR-R1H716 R1 Sway Bar Set
SPR-R1B802 Set Screw M3x4
I think they are all you need you might need some additional
SPR-R1A102 R1 Alu, Ball Studs 5mm and
a few more ball cups.
#2849
Other than looking nice, why are you all getting the aluminum fan mount? The plastic one works fine, except for blocking access to the spur layshaft screw.
#2850
I agree about the plastic one being just fine. My Pro Spec came with the aluminum one, so I use it. In almost all cases, the plastic parts are much lighter than their aluminum counterparts, so if isn't a highly stressed part, the plastic part will often be the better option.
