Team CRC Xti 1/12th Scale!!
#2057
Two questions regarding center shock mounting at big races or anywhere with the new carpet.
1) Are any of you changing the mounting of the shock to a flatter angle? Looking at other brands, they have very flat angles for their shocks.
2) Are any of you running 0 degree caster blocks? I have seen that once, but are more of you doing that?
It is acceptable and encouraged that Mitch W., John W., and Slapmaster jump in here.
#2059
#2061
I always run the 5* blocks with 2 shims forward.
Lmk is you have any other questions.
#2062
As to your question about other brands, a flatter shock angle and a longer shock can have its benefits at time. A flatter shock is going to provide a more progressive feel where the more the shock compresses the softer the compression actually gets. I think this is a preferable feel in Mod where you are trying to make the car more drivable and smoother. However, in Stock and 13.5 it isn't preferable. In fact, many of the other cars actually work to get more angle in their shock when they switch to Stock. The CRC shock angle provides a super linear feel throughout the entire shock motion.
2) We ran 0degree blocks on our mod cars at IIC and the setup that Andrew Knapp won on used 0degree blocks. However, this is something we really only do on mod as it takes away steering and again, much like the shock angle, smooths the car out. In Stock I don't see the 0degree blocks as being something you would want to do. I do believe at times Mitch W. has ran 0s but then he turns his steering DR up to compensate for the loss of steering.
My suggestion on this is just run the 5degree blocks and save yourself a lot of hassle.
I spoke with Brian Wynn and he said that Frank is in the process of adding new parts to the website now. Expect that to happen pretty soon.
#2063
No, I have a 2mm spacer on the top plate and a 1.5mm on the antenna mount just to clear the battery. I'm running what amounts to the crc green center spring and the shock is as short as possible (stock). I could see changing the lengths of the shock for 13.5 or mod but not stock IMO.
#2064
anyone using a different bladder in their shock? kind of hard to set rebound with that bladder, personally
#2065
Yes
John, thank you very much for your reply. Great to hear what you are doing with your car. Anything about your thought process for these setups is valuable information for all drivers that are serious about advancing their skills and speed. My hope is that there will be growth in onroad RC racing and things like this can be instrumental. It is time for American drivers to challenge in the world stage of onroad just as in offroad. It needs to start in stock and can move into modified over time. But starting this in stock is essential to get the right drivers involved and prepared.
#2066
Witta, what steering servo you use in the HC cars? Thanks in advance
#2067
You can purchase them here:
http://www.serpentamerica.com/shop/p...&cat=57&page=1
#2068
thanks for all the great info guys. getting to put it down on 360v2 tmrr for first time
can someone repost the link to converting the x10 to the new car. if this goes well im going to pick up the 1/10 as my shop has one collecting dust
#2069
Bill
