Team CRC Xti 1/12th Scale!!
#1861
Yes 4mm works. It's a bit loose but will get the job done and is what I use. 5/32 is the proper size.
#1862
#1864
Hi! Just ordered a CRC Xti wc. Will go thru this thread, but trying a shortcut by asking here first.
I have a Xray x12 now, and know some about 1/12Žs.
Most cars have there own tricks, so how about this one, is there any known "tricks" to it.
About screws, it looks like all countersinks are steel, is there a kit of titaniums or do i have to buy all separate?
Seen some guys using other brands rearaxle/diff?
How about setting, iŽm new to the class and we run on a midsize to tight mediumgrip track, is the stock (building) setup ok?
Thanks!
Thanks!
#1865
Thanks!
Thanks!
#1866
The stock setup on the WC car is just fine. There is one tiny omission in the instruction sheets however. The encore shock comes with 2 o-rings. One goes in the obvious place to seal in the oil. The other one goes on the shock shaft and acts as an internal spacer and cushion so that under full extension, the shock piston lands on the soft oring insead of bottoming out on the hard bottom of the shock body. Aside from that one little thing that is not explained in the manual......your car should work great if you build it 100% per the instructions. Tire size and choice and how you sauce your tires are perhaps the most important things to "tune" the car to your personal driving preference. While maybe not the absolute fastest, black fronts with grey or greylo rears are usually a good solid and easy to drive tire selection. Those work best on my home track since we tend to get some fuzz pickup and that family of tires is less prone to grabbing fuzz off the track. But if you want every last ounce of performance, you may want to try some blu or double blu fronts in combo with either blu or greene rears. Happy motoring.
We are running doubble pink front 43mm and green rear 44mm and that feels ok, but on the otherhand i havent tryed else! How about sause, our advice is "Spider" green, since that is better to the foam?, and how long before driving is good?
#1868
Was just thinkin that! We have i guess the same 730g incl transponder. So if the car is that light there is good to have the weight down low, right?
#1869
No one that I know of changes the rear axle in our cars. Our diff is super light and easy to make smooth.
The stock setup works just about everywhere. Probably start with 10k in the tubes.
Get yourself a quality 1/16" hex wrench and a good 3/16" nut driver.
Brian Wynn
Team CRC
#1870
Ok, thanks for those positive words! Really looking in to building and start driving this car!
Is there some special things to get as spare and options?
#1872
Ok, iŽll order those parts then! Thanks!
#1873
Why is there, Reinard had the TRF Tamiya logo on the previous world's?
#1874
What configuration are people running this car in? Have we all switched to Altered Ego and the transverse layout or do you still have success with an inline car?
I ask because on high grip my transverse car tends to lift the inside rear tire, and running inline and getting that weight forward in the car seems to be the only fix I can think of.
#1875
Have started building the car with a couple of issues. When putting in the small steel balls for side damper rods one snapped because of too tight hole. Then the 3 supplied caster uprights there was 3 zero degree, 1 five degree and two 10degree. The manual says to use five degrees as stock. Well well have to start with either 0 or 10? I have emailed crc with pictures and waiting for reply!
