YOKOMO Touring Car BD-7
#6421
You're welcome.
I don't have the short shock conversion for my '14 or '15, so I am not really sure about the size differences, but I doubt it would work. So my guess would be, that that sheet is indeed a little off on this detail, but I could be wrong. Sorry, no definite answer here.
#6422
Hi all.
Im new on this site anew am going to be racing again after 15 years. I just picked up a 2nd hand bd7 15. Has anyone got any tips
Do the short sticks make much difference
All info helpful
Cheers
All info helpful
Cheers
#6423
#6424
For such small parts, I would try the trick I used to do on some of lab machinery and use a high power soldering iron applied directly to the aluminium. Keep in mind it might affect the anodising colour. I used to take interference fit pinions off motor drives like that. I guess anything that will heat rapidly and locally is good (with variables).
These days, I would try the freeze and release agent first though. That is also a lubricant. I have had some brilliant results pulling sheared studs out of engine blocks I would have just scrapped in the past.
#6425
anyone knows the size of bdy steering rack bearing?
#6426
Nice!
#6427
Conversion or full kit??
I currently have a 13 and 2 x 14 bd7s. I have the oppurtunity to get a conversion kit reasonably cheaper, but I'm thinking of a full kit. Can anyone give any pros n cons w my situation?
Thanks in advance
Thanks in advance
#6429
If your cars are in decent condition(free of any kind of tweak you haven't been able to isolate), I recommend the conversion kit to be used on your 2014 car. The conversion kit is the most EXTENSIVE to date and replaces a huge amount of parts making it difficult to distinguish it from an all new car kit. It's shocking how much is new save for plastics and bearings. This is the cheapest way and a huge bonus for owners of older kits to stay up to date. It's great that Yokomo makes a great effort to offer a conversion kit to save a few bucks.
Pros-
Cheapest way to get the latest car with majority of the higher priced parts included(i.e. Bulkheads, shocks, chassis)
Cons-
-new bearings, driveshafts and plastics included in new kit(however these are the cheapest and most frequently serviced parts with the shortest operation life. You've likely already replaced these recently.)
-Fresh and tweak free suspension blocks( if you car tracks straight and turns equally left and right, chances are your existing blocks are perfectly straight.
Bottom line: if your car is in excellent working condition,which most are, it's just wasting money buying an all new car kit.
#6431
Hi Will,
Pros-
Cons-
Pros-
Cons-
Thank u for taking the time to reply. Let's say if I do get the conversion kit n transform one of my 14 to 16, can I then w the old 14 parts convert my 13 to a 14??
#6432
Hi Will,
Pros-
Cons-
Pros-
Cons-
#6433
I have just received my bd7 16 new kit after deciding to switch from from running Tamiya trf's for longish time.
I will be running outdoor on low grip tracks. Are there any must have parts or upgrades I should get before I start building?
Many thanks
Many thanks
#6434
Yeah. All the parts in the previous kits. That should just about cover it.
#6435
