Like Tree6Likes
Old 09-18-2015, 08:47 AM   #6121
Broke my drive shaft last night, it is not the standed shaft, double joint. Is there a manual for it? With part numbers, because someone got up the inside of me and car went flying.
tiny tom is offline   Reply With Quote
Old 09-19-2015, 05:01 PM   #6122
eyyy guys going to release a new model, BD8? or there will be bd7 photos or know something?
electrojer is offline   Reply With Quote
Old 09-19-2015, 09:44 PM   #6123
Trader Rating: 23 (100%+)
Awesomatix A800X | Team SILVERBACK | LRP | R1WURKS | FUTABA
Zhangesh is offline   Reply With Quote
Old 09-20-2015, 02:11 PM   #6124
swerv512's Avatar
It's been almost a decade since i Iast raced and want to return slowly. My last car was a HB Cyclone, bought it the moment it was released way back then. Looking for a car I can grow into and I'm looking at a BD7 RS3. I figure I can save a few dollars to invest in electronics since I'm starting from scratch. Would there be reason NOT to buy a BD7 RS3? Yes, I know- the money I spend upgrading will be greater than just buying BD7 15 black, but I have to watch my initial investment or else... Appreciate any response.
swerv512 is offline   Reply With Quote
Old 09-20-2015, 04:00 PM   #6125
beidle99's Avatar
I have a 13 for sale that would be better than the rs for you (and cheaper) The link is in my signature.
Mugen MBX7R, Fusion X5 Race "FM", Houston's Engine Service, 2096/41021, Buku Komp
Mugen MBX7 Eco, Hobbywing XR8, SMC 1900, BCE X3.
Team Driver for FusionX Engines & BCE (RIP Bill)
beidle99 is offline   Reply With Quote
Old 09-20-2015, 08:38 PM   #6126
Roger H's Avatar
Trader Rating: 19 (100%+)
Anyone have the actual spring rates?
Roger Holmes
TLR Maxy's Engines Airtronics Proline RC Juice Horizon Hobby
Roger H is offline   Reply With Quote
Old 09-21-2015, 05:13 AM   #6127
Bar
Originally Posted by Zhangesh View Post
unlikely to be a new model for 2016, they will probably release a special version with some parts as standard (think DCJ's).
BD9 will likely be released in late 2016 for 2017
In less you have some inside information there will be a 2016 BD7, Yok have for the last so many years brought out a new car every year same as Xray does. I think the stupid name changes have gone and that only the year will change, Xray have already said they won't be changing the T no's anymore.
Luke Burr
Bar is offline   Reply With Quote
Old 09-21-2015, 03:22 PM   #6128
Originally Posted by Glarke View Post
Heya guys, looking for a bit of help. My first weekend with a touring car the other week and I was running setup as described below.
Car was very pointy into the corners (so much so that for the first lap or two I would clip apexes), and a little pushy on the way out.
What should I be looking to do in order to calm the steering down on the way in and gain a little from mid corner out?
Adjust ride height to 5mm both front and rear. Make sure you do not have any drag brake on. Reduce steering throw. Try standing rear shocks one position. If that doesn't fix it, try harder rear springs.
What bodyshell are you using?
buzz777 is offline   Reply With Quote
Old 09-22-2015, 12:35 AM   #6129
Korey Harbke's Avatar
Hey Everyone,
I've decided to put my backup BD-7 2015 up for sale. PM me for details.
-Korey
Korey Harbke is offline   Reply With Quote
Old 09-22-2015, 12:57 AM   #6130
Thanks for the reply. Running a Bitty Nardo shell at the moment, but have a Mazda GX on its way to try too.
I ran the car last weekend after taking a half mm droop out of the front which helped in the back half of the turns, but Ill try your suggestions when I get back on the track next weekend and see how I go.
Possibly just a bit of time getting used to touring cars will help.
Glarke is offline   Reply With Quote
Old 09-22-2015, 08:02 AM   #6131
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
GX body is a good way to free up rear end
Doubt that's what you are looking for
Speed 6 for carpet
LTC for asphalt, most popular bodies on a BD7
Old 09-22-2015, 09:43 AM   #6132
Bar
Speed 6 for carpet
The Speed 6 is also really good on asphalt, depends what the track is like and what tyres you are using, it's the only shell I use on my BD7, we use the Sorex 32 as the control tyre
Luke Burr
Old 09-23-2015, 12:42 AM   #6133
Default anti roll bar setup
Does anyone have a good link to a step by step setup for getting the anti roll bar correct as I can not get to behave properly and when I lift up wheel the other side never moves and I have adjusted everything
does the middle roll bar stabiliser move or should the set screw be in far enough so it doesn't wobble around in between the holders.
Should the roll bar itself be able to move or slide from left to right within the rollbar holders at the front. I have tried tighten up the set screws as much as possible but the roll bar still seems to slide from side to side
BruceCampbell is offline   Reply With Quote
Old 09-23-2015, 05:52 AM   #6134
The stabilizer should be tightened down as it stops side to side movement. The bulkhead set screws just account for the thickness of the sway bar so you should tighten those until you get a little resistance from the sway moving freely and then back them off a little.
The only way to see them working is to take everything off but the arms. Too much weight and too little travel to actually see how they're working with everything together.
2uzferunner03 is offline   Reply With Quote
Old 09-23-2015, 07:21 AM   #6135
Salkin's Avatar
+1
I also check it with only the arms and everything taken off.
When adjusted like this, and if your arms does not go up at the same time when everything is attached, you have an indication that something binds elsewhere (hubs/hinge pins etc.)
Yokomo BD7 2016 Black Series - MuchMore Fleta Pro / MuchMore ZX - Highest DLP650 - Sanwa M12
Salkin is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 03:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 04:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 01:43 PM
