Yokomo MR4TC-BD
#3901
The front end of my BD is sloppy, specially on the steering plate
#3903
carpet 19 set up
Guys,
After having a good year in stock/foam, im stepping up to 19t/rubber.
Any help/suggestions on a set up (tight small track, 12sec stock/foam laps)
pLEASE............................
Ive never raced on rubber b4, so any help is apreciated.
Simon
(any links to set ups?)
Simon
#3904
i have a question for all racers out there
i use a
yokomo BD,
ko 2343 servo,
ko VFS-1,
spektum radio system,
silver can 540 Johnson motor,
sanyo 1300 scr batteries (best punch, limited to 1500Mah for this class)
i have to use 120grms of weight to get to the 1500 weight limit
the question i have is that, instead of using weights to get to the weight limit, if i used a reciver battery pack for xtra weight would that
a. give more run time,
b. allow to gear up for better straight speed (for long open tracks)
c. effect servo speed,
d. work with the spektum system
e. have any ill efects that i havnt thought about,
any ideas would be cool
i use a
yokomo BD,
ko 2343 servo,
ko VFS-1,
#3905
If possible, you could hook it up with the regular battery and that would boost voltage.
#3906
You will get more run time as the servo is being powered by the reciever pack. Check the VFS1 thread on how to connect it up. by the way that servo uses alot of juice!
#3907
i use a
yokomo BD,
ko 2343 servo,
ko VFS-1,
i use a
yokomo BD,
ko 2343 servo,
ko VFS-1,
No offense mate...... it's like a Ferrari with diesel fuel
#3908
In NewZealand "stock" is limited to 540 silvercan motors, 1500Mah batteries and rubber tires.
It is our most popular and competetive grade with even our top drivers racing.
You'd be surprised how well these 540's run at between 4.3 and 4.1 FDR.
I use a pro4 in the same grade. geared 88/51 giving 4.21 FDR.
The racing is very close and we are always looking for ways to maximise the performance with this setup.
#3910
it would be more suited, if you check out a well known auction site you never know what you could find
#3911
Originally Posted by asw7576
LOL, you have nice BD + VFS-1 but you are using Johnson 540 motor & 1300mAh batteries ?? OMG !!
dont worry i run our Version of mod over here with a BD as well, in that i have the same gear but run a checkpoint 12 turn (thats the limit) and Peak Powerflow 3700mah batteries and that goes tike a dream
#3912
#3913
its all about sweet lines and no crashing, if you do then you might win the race, there is nothing you are allowed to do to the motors cannot tamper in any way so really it comes down to driver skill rather than money and best equipment, a good driver with okay gear can beat a bad driver with the most expensive gear
#3914
We race the johnson grey endbell in Aus...It is a competitive class(but you always get the one or two that try and cheat)but we use up to 3800 batteries and open tyres.Stock(27 turn fixed 24degree)is ultra competitive in Brisbane...15to 20 at a club meeting...the only down side to this is you have to use good gear ALL the time ,even club racing.
#3915
The silver can 540 is far cheaper then a stock motor and just about as fast if you know what you are doing, plus no brushes to replace or coms to true. At my local track I run 3.7:1 for ratio with silver can!
As for receiver battery packs, I have a number of them that I was going to try, but after looking at the consumption in my 1/12 after an 8 minute race, probably 10 minutes run time with a digital servo, I used 20mah, not worth worrying about to me and could cause more problems with no benefit.
