Hot Bodies Cyclone
#5011
Originally Posted by rc-zombies
US spec spool has the aluminum outdrive cups.
World spec has the Delrin cups.
both with aluminum bodies.
BMI spool.. being revised to fit the new style CVD Blades.
#5013
yakuza, no problem with the help even though i may not always be right. on droop my understanding is that lower number makes the car react faster which would be more useful for quick direction changes. on high speed track i'd try less droop up front like 6 - 7 and in the rear about 4.5 - 5.5, higher if theres good traction. its worth a try at least.
peace out
peace out
#5015
Front one-way outdrives
I drove the car today and all I gotta say is " WOW " !!!! Very nice car and very easy to drive. I noticed something about the one-way differential outdrives. They look like they are almost coming out of the front one-way unit on both sides ??? Anybody know whats going on with this ? Thanks.
#5017
roger..
are you using the stock cvd?
on mine I have the shorter Tamiya 42mm steel cvd's... and I had to place some 2mm spacers on the outdrive to move the one-way cups out.
you coming to race at the Rock's Shootout this sunday...?
Yeah, im using the stock CVD I believe. Thats the one that came with the car. The front CVD's are fairly smooth when im on throttle while turning the front wheels. No clicking noises of binding whats so ever. Where do you guys get your cyclone parts ? Thanks again.
#5020
Please help, I'll be soon part of the Cyclone family, the car will have the older black diffs,plan on running carpet and upgrading to the aluminum diffs
1. will the version2 dogbones fits the older diffs or aluminum diffs.
2. Does anybody make a aftermarket diff screw i.e. titanium
3. Cage thrust bearings x-ray, corally or tamiya will they fit the cyclone?
4. des anybody make diffs sheilds for the cyclone, thanks
#5024
Originally Posted by lawtonlosi
How about some steering spindles?
Try T2 spindles with a .025" shim and your good to go, stronger too.
#5025
Has anyone bought the diff set from Stormer Hobbies? I can't find anything from HB to say they actually do a complete diff set and find it hard to believe that they can sell a full diff set for just $5 more than the price of the delrin outdrives. Is it exactly the same as a standard Cyclone's diff?
