Hot Bodies Cyclone
#2296
Originally Posted by danjoy25
So whats the wear on using a front spool like?? Im thinking of trying it with the steel front CVDs for stock racing, but is just concern about the wear that it will bring.
#2297
I am planning to get the TiR CVD to run the one-way or front diff. How durable are the CVD? Do the axle get broken easily?
Also, have anyone heard or have experience with the Mechanica Ceramic Bearings?
http://www.precisionrc.com/nv/car/pr...oduct_id=12535
#2298
I am having problems with my T1R CVD's after two races, i will be going back to stock cvds after the next rebuild.
#2300
I have had no problems with my spool at all but then again i have not used it much.
#2303
I ve used for the past 20 runs TIR's front spool with the derlin outdrives, the so called "PRO COMPETITION SPOOL"
I use the stock HOT BODIES lightweight aluminum outdrives which are also supposed to be fragile.
I run on a very large, high speed, medium traction track.
I 've had great success and not a single failure.
To my understanding, running a spool, even one made of steel, is not recomended for high bite/traction, carpet tracks.
As also seen at the ICC LAS VEGAS race a diff upfront is the better choice.
Spools cannot absorb the energy generated from cornering and accelerating as there is no moving part to give way. In this respect when traction is high, it is normal to have problems with durability.
Manufacturers are trying to built them as light as possible to enhance performance, not to make them bullet proof.
I think TIR's spool is as good as they can get. Just stay away from crashes and don't use it on high bite carpet tracks.
#2305
They are different. I agree that they are expensive compared to the $5 ones that HPI and Yokomo has for there cars. I would suggest to wait for the alloy version coming out with the new cars.
#2306
Where can i find the new HB Steel set?
I have tried in several e-shop but no one have it.
#2307
Originally Posted by S-T-R-l-K-E-R
try hara's baseline setup. it rocks!!!!
Do have link to this set-up?
#2308
JonboyGB
Its on the hotbodies site,its Hara's set up from the IIC in vegas,he was pretty dailed in the main.Heres a link
http://hotbodiesonline.net/Set-ups/cycln_05IIC.pdf
#2309
Originally Posted by Andrew_Carter
JonboyGB
trivia: hara handed me his written set-up sheet for the IIC. and there are a few things diff on the website compared to the original.
its on top of page 40
#2310
I found it Striker,cheers
Laters
Laters
