Hot Bodies Cyclone
Trader Rating: 25 (100%+)
Depends---on how big a PINION you run!! I ran a 80 tooth with a 56 pinion this past weekend. I could have gone down to a 74--it would have fit.
FYI
Tim
FYI
Tim
I have been surprised several times by a diff that is great when you spin it on your table, really free without slipping, etc, but is in fact a total junk when on the track. Then you spend the afternoon chasing setup, and then just to be on the safe side you rebuild your diff...et voilą! the car is great again and you can undo all the desperate setup modifications you had done. One afternoon lost ( if not one whole day) sometimes a set of tires, and a bit of frustration coming home.
So, these ( relatively rare) bad experiences have me rebuild my diff every 10 runs or so, just in case... and that is super boring. To answer your very justified doubts about how I build/clean then, I took lessons from the greatest diff specialist of all time, the legendary www.overrc.com. I use the right greases in the right places, the rings and balls are perfect, same for the thrust, etc.
Sooooooo.... how can I put this NT1 diff in my cyclone ?
Gear diff could be a good idea for maintainability... But you'll lost the "slipper" effect...
The NT1 diff is 55$, I suppose the SpecR one is more expensive...
For the TCD, I emailed RcChamp and they answered me that the steering parts are sold out... Asked them for how long... No answer... I'm really thinking of getting the kit itself... And resell parts...
I am running 10.5. I have the plastic diff- probably the best plastic diff I ever had, admittedly . I understand your comment, I 'll try to explain.
After a while i have noticed the diff overheats (either because it is to loose or because the grease is gone).
It will seem Ok in the bench, but if you test it imediately after the run you notice its super tight and grety. once it cools down, it will seem ok again.
The alu outdrives seems to help the consistency of the diff also.
About the gear diff, sorry, havent tested yet :P
Good luck
Two type of DCJs?
I have two sets of DCJs one is from japan and second from usa and japan version have cross pins vs usa version that have parallel pin. Is there any difference in performance?
cross:
parallel:
cross:
parallel:
Howdy,
I've recently developed a mid corner oversteer problem. Doesn't seem to matter if its a high speed or tight slow speed corners.
The track surface is painted bitumen with medium+ grip depending on weather and conditions.
I have recently changed from Sorex 32's to Muchmore 32's and was all right for a few meetings until in the last two outings welcomed me to oversteer city.
I generally run the HPI blues with AE30 weight oil with 2 hole pistons with no rebound rubbers. It was recommended by a club member to try going to Silvers which helped a little and when I tried the Pinks it was just as bad as the blues.
Any suggestions on things to try and change to eliminate the oversteer would be greatly appreciated.
Run hpi white springs in the front and you blue springs in the back middle shock tower positions.
2 deg camber all around go from there should plant the rear nicely. if to much over steer drop the rear shocks down. under steer drop the front shocks down. lower traction all around drop all the shocks down. there should be a decent split front to rear in shock springs front harder than the rear. just play around in the spring range i gave you. its rare to get a car to handle great with same springs all around.
Howdy,
Sorry for my english, i hope help you.
Luis C.
Howdy,
Thanks all for the responses. There is a club meeting this weekend that I'll give the recommendations a go at. I'll let you know how I get on.
only with the 25.5 motor does the FDR limitation go away -- unless you're track doesn't follow the USVTA rules
