Tamiya F104 Version 2
#767
[QUOTE=Mr.juarez;11612836]
Went and practiced some more today. As you can tell by the pics the roughness of the track. Im running the pits front and back and its pushes just as bad as the rides f1 tires. I added the aluminum rear diffuser and lower plate and it did gain traction in sections where I would spin out before. Everything is stock according to the manual at the moment, but I did get the front and side springs yesterday so if anyone has a suggestion please do tell.
Pitch damper has 30 oil and 20 the side one. God I love this class!!! :Ive gone with black side springs on mine and its probably a dustier track than you
#768
Ok when you guys changed the side springs did you guys keep the as per manual length on thw set screw? So when I change them tonight to pink or black leave it or go in more?
#770
Hey thats sealed a few months ago. Add the cold weather (40ish) and cloudy and it becomes tokyo drift later on. Oh and there is no traction spray either as it gets cold it comes off then we really go for rides. But hey better than nothing though
#772
Im running the 93 spur kit and the 23 pinion from the kit and its got too much top end. My track is 100x 60ish with silver can. Try the 104 and 23
#774
#776
Here's a promo video we've just finished to get everyone hyped up for F1 in 2013. The footage was from our Cup Series which was won by a v2.
+ YouTube Video | |
#777
We ran 17.5's in F1 at the Nationals in November and they were much harder to drive than 21.5's. Like you I turned down my throttle EPA in my v2 until I got the hang of it. Luckily we've now standardised on 21.5 in Australia for national events although some tracks still run 17.5.
+ YouTube Video | |
#778
In particular we have a v2 page which has a compilation of links to reviews, builds, tech articles, setups, etc. Hopefully it won't keep you from your sleep for too long
http://www.rcformula1.com.au/index.p...resource-index
#779
short pack battery all the way back
hobbywing just stock ESC between battery and motor
rear chassis right high is 5mm, and 6mm when the pitch damper full extend
pink pitch spring with tamiya yellow damper oil about 400cst.
rolling spring: tamiya pink spring
rolling damper: damper tube and damper shaft with 20000 cst damper oil.
rear pod right high 6mm and 0mm droop when the car is off the ground, means it is level with the chassis.
100% throttle EPA and 66% steer EPA
shimizu rubber tire
