Xray T1FK05
#1216
Originally posted by Noel_E
Yes the KF04 Sway bars will work with the FK05. Mine's fixed and looks just as nice.
where can a guy get some aluminum rear, front and steering knuckles @.
#1217
Originally posted by tc3Guru
awesome.
awesome.
#1219
Hi All
What 64 pitch spur gear should be bought to fit the T1FK05?
Scott
Scott
#1221
thanks
#1222
Originally posted by TreyDog
anyone notice the front diff has a lot of left/right play when mounted in the front bulkheads? at least mine does...
#1224
yup, 1mm play in the front. the rear is nice and snug. just doesn't seem right but if that's what it is, it is what it is...
#1225
Lino my FK04 and FK05 both have a little bit of play in that the diffs can move back and forth around a 1mm, although I dont really think it does anything, I mean think about how much play the tc3 had, lol.
#1227
You could always shim the diff... Looking at my car the long belt looks like it comes real close to the servo saver/steering post, I don't know if I should be concerned if it will touch or not. I don't recall how much side to side play there is with my front diff, but if there is some I guess I can try and shim it to give a little more clearance between the belt and the post.
I haven't got as far as mounting electronics yet, but I am starting to be concerned as my equipment isn't very small... I have a KO 2123 servo, a TC2, and an airtronics synth rcvr. Perhaps I have room to mount the rcvr on top of the servo... My other choice is to pick up some smaller components, just not sure how much luck I will have in finding an ESC at the Toledo rc show this weekend. Best I am hoping for is perhaps a smaller servo. Can anyone recommend a small servo, preferrably KO or Airtronics. (Fut 9550 I am already considering)
#1228
Does anyone know what effects it has when you move the rear shocks out on the rear shock tower.( from a 4 to a 5 to a 6 position) I noticed that the kit set up calls for a 4 but on the generic rubber set up it says a 5.
Sorry but as you can tell I havent got my car yet so all I do is research setups and so on.
Also what about downstop. Most all of the set up sheet says use a 1 or 2 up front, but they vary from 2 to a 5 in the rear. What would be a good starting point.
#1230
tc3Guru, I have a Novak RX with a GTX. To make room, I used the 2 most forward servo mounting holes on the chassis. But I had to shave off about 1 - 1.25mm of the servo mounts and extend the slots on the servo ears toward the servo body. I also shave down the antenna mount on both sides and counter sunk a new hole next to the servo. Now there'e enough room to lay it all down and still have room for bigger pinions.
