Ofna DM-1 Spec Electric 1/8 Gt OnRoad
#151
50bucks is the cost of the HK motor, and they fly!
and it is possible that the cc1512 motor is to small for an EMaxx but he HK 2560kv is killer in one! the HK motor has more poles = more torque
so what does that say? higher priced china built motor vs a $50 china built motor....
#152
#153
HK motors often do not even get to 80% efficiency. CC motors go into the 85% range. Only few go higher then that (Neu, Lehner)
#154
wow, looks around, read, and learn some before posting
6 pole motors have more torque than 4
also they have more efficiency than 4 pole motors
see the trend here????
and only 50bucks to boot for the motor I'm talking of...
Leopard motors are around 90% efficient! (hmm, better than what you say Castle is??)
many HK motors now days are much more efficient than some of the name branded motors
no reason to pay dump prices today for performance
#155
Prove it or go home and do your homework first. Cause you're so very wrong I don't even know where to start. It appears you are shouting things you heard other people saying not even knowing what the hell they were talking about. 6 poles can produce more torque is about the only thing you know?
#157
What's the setup on the Dm-1 spec in the vid? Gearing, esc etc...
#159
sweet ! what lipos ?
#160
Prove it? does this mean you cannot read, or your mommy still helps you go pee? Ignorance, yes?
its called the WEB/Google?
heard of it? use it...
what I'm talking about comes from experience not from your ideologies..
one motor I use is a NUE1521 1.5D and I'm going to run this aganist this
and you might want to actually read some specs on other motors like this one before shooting off your mouth next time
http://www.offshoreelectrics.com/pro...o-4092&cat=148
I own a NUE motor and some MEDUSA motors as well, along with about 15 Castle motors
Castle motors do kick A$$!
#161
great job man...
#162
And yes I did do my homework, I did study the specs (that tell you nothing unless you also read graphics charts from test runs ) and I did do the one on one comparison tests.
I wonder why you want to compare a 3500 W Neu against a 2400 W Leopard. also I wonder if it's a Wye or Delta model. And then are you going to compare your delta againts a wye? or wait....you probably don't even know the difference right?
Never mind, good luck with your Castle motors and keep supporting the economy please. Nighty night.
But shall we return to the onroad racing now, that is, I presume you don't want to put your 1521 in a 1/8 scale GT car I hope....
#165
Excellent Video!!!. What spur gear was used ?.
