which esc
which esc
which esc should i get the quantom sport or the ipc super sport.
thanks.
thanks.
easly the quantom..........its the higher version of the ipc
If you can find a cheap ko vfs 2000 i'd go for that or if you can't go for the newer ko vfs-1, all ko equipment is good
Chazz
Chazz
LRP7.1 can take serious abuse
Hi,
Go for the newest Ko, the VFs-1pro.
It's as small as the QC2, and it's better.
Both ESC aren't watherproof
Thomas
Thomas
If you want a waterproof 1 dont go for a quantum 2! they are definately NOT waterproof, not even dampproof. They tend to work fine in your race then afterwards when you turn the switch off they randomly turn on and whack your motor to full speed, then blow up an seep resin everywhere. Trust me ive had it happen 3 times now .
