Team Much-More cell master v1
#406
Originally posted by Guo Chean
Hey does anyone know where can i get the whole instruction manual for team much more power master because i need to switch the input power from 110 volt to 240 volt when i bring it to back to my country so i do not want just because i not familiar with this power supply and causing it damage. and second question may i know for the glass tude fuse in 250 volt and 5 amp where to get in United States or i just using 110 volt ad 5 amps fuse? thanks
#407
Shop Owner
Nick
#409
Nicad Charging
Flex mode is not available in Peak Charge mode.
To use flex mode for NiCD you have to use CTX Function.
thanks
thanks
#410
TeamMuchMore-U have a PM!
#411
I used the cell master first time this weekend.
my packs have more punch! and they don't fade at the end of 5 min racing.
step charging rocks!
SWEET!
SWEET!
#412
Originally posted by kumpol
I would use:
5.0A Delta peak 06 Temp 48 deg.
instead of step charging.
but you can try what Arun posted.
I would use:
#413
I found this on much more website:
step charging doesn't do much for nicd?
>Hi,
>Can I use step charging for Nicd 2400 cells, if yes which settings are good.
According to my test during 2004 Tamiya race in Hongkong,
for high initial power (it shows high power till 2~3min)
1/3 7.0A 1600mAh
2/3 0.2A 1630mAh
3/3 4.5A 2800mAh
Temp 48 degree
Delta peak 06
was great but after 3min. power getting low,
For linear power from start to the end
worked fine.
Please try above setting then tell me the feeling.
If you find other better set up, feel free to ask us.
Ryan/Muchmore Korea
1/3 7.0A 1600mAh
2/3 0.2A 1630mAh
3/3 4.5A 2800mAh
Temp 48 degree
Delta peak 06
worked fine.
Ryan/Muchmore Korea
#415
Guest
Hi all just wondering if you put the IB 3600 CELLS in Zero racks? I have heard that they dont like being zero`d is this true? 1 more thing does anyone have a CTX charge profile for them thanks. Where do you get the profile from off the mucmore page I had a look and can`t find them.
Thanks for the help
Thanks for the help
#416
Thanks for the help
Thanks for the help
Steps 1st
current 7.0 A
capacity 2650 mAh
Flex off
Steps 2nd
current 0.2 A
capacity 2680 mAh
Flex off
Steps 3rd
current 4.0 A
capacity 4100 mAh (+)
Flex off
delta V 06mV (6cell)
Temp 48 (48 degree Celsius = 118.4 degree Fahrenheit)
repeak 1 delay 5min. repeak capacity 250mAh
#417
Guest
Thanks I will give that a go. What about putting 3600`s on Zero trays
#418
