Ta04r...
#1472
At the European TCS finals the tech inspection cut open all of the finalist tyres to check if they where not using B-types instead of B2's or A's. Those tires are marked differently on the inside.
#1473
Originally posted by linger
Coop,
The springs were used. I don't know if age relaxes the spring tension or if use cold works them - increasing spring tension. Those were the only springs I tested.
Coop,
Coop
#1474
Hey guys, with the TCS race getting closer and closer, I just realized something, I don't have a raceable Tamiya Body. Is the Modena still the body to have? How about the NSX or the Skyline?
#1475
jackhammer74
At the TA race a couple weeks ago, a lot of guys were putting SS arms on their 04R's and running the Abt Audi TT bodies. In case you're concerned about the rear wing, it's pretty tough.
#1477
What body???
It depends on what your car is doing. In GT1 1st qualfier, I ran a Modena and my type-A tires were overheating, causing my car to overrotate on corner exit. I was qualified somewhere midpack in the A.
I swapped to the Skyline body to keep the rear end in check for the 2nd qualifier. Instant TQ and win.
Don't count out that old Skyline.
I didn't have time to paint up a NSX body though.
#1478
TCS bodies...the saga continues!
Prior to that it was the Modena...but it would be hard to argue with the Linger, as his car looked very balanced in the main.
#1479
Thanks a lot guys, now I know what to pick up the next time I go to the LHS, I think I'll get the NSX, plus I'll keep my old skyline or "old reliable" on standby just in case.
#1481
is there some sort of spring chart for tamiya???
can someone order these from hardest to softest
blue white yellow white
blue and white are pretty close which one is harder?
#1482
From soft to hard.
RED
YELLOW
BLEU
WHITE
Between bleu and white there is litlle difference.
Still white is the hardest at this time.
RED
YELLOW
BLEU
WHITE
#1483
Originally posted by izzyracer
Make sure you get the lightweight
#1484
Eletric problems
I'm having a glitching problem in my 04R and I can't get it to stop. I've change receivers from AM to FM servo's and motors the car still glitches. I 've mounted the receiver on the opposite side of the servo with the antanna wire coming out the middle of the car not all the way in the back by the motor and it still glitches
#1485
Re: Eletric problems
