Team Losi JRXS
#6841
Originally Posted by elnitro
guys, I'm helping a buddy build his JRXS and was wondering where he can get this bk bracket. I went with him to the hobby shop and the dude behind the counter gave us a blank stare as if we were on crack. LOL Is there a part # for this? Any help would be appreciated.
See 6831 post ..... "Pookyt"
#6842
Did anyone have any problems with the rear wheels touching the shock screw when using offset hubs? I even tried dremeling and it still hits the wheels.
BTW, I use the shock in the outside hole on the arm. I tried moving it to the inside hole, AND IT WASN'T HITTING ANYMORE, but then the rear was going all over the place (slipping) when cornering, so I assume I need more rear traction, right?
Right now I'm thinking about forgetting about the OFFSET hubs and go back to regular ones.
#6843
The Evicerator
Originally Posted by Randy Caster
9 and 10mm above ride height for droop? Jeez Steve, you like your droop man!
#6844
Originally Posted by JRX-S Bill
If these guys are 'down under' are we 'up over'???
Will our setups even work in Australia??? Makes no hemispherical sense to me...
Brant
#6845
Brant
#6846
#6848
Car Turns Better in one direction
Hey,
My car seems to have more steering in one direction. My droop all the way around the car is even as well as the ride height. When I placed my car on a tweak station there is apparently more weight on one side of the car. I know that I can adjust the collars on my shocks but if I do so, my ride height will be greatly affected. Any ideas what is wrong? Is there such a tool as a shock or spring dyno? Any help is appreciated.
#6849
Originally Posted by Intelligentsia
Hey,
If it's a shock issue, Losi makes a shock matching tool which checks the rebound and friction of each shock against eachother. Follow this link for a more detailed description.
#6850
Originally Posted by POOKYT
Make sure your using button head screws to give clearance. I have not had the brackets on with offset hubs so I'm only guessing this will help. Let me know if it does.
Brant
Brant
#6851
First of all, THANKS for the help guys, helpful as always!
->>It doesn't rub anymore(using button head screws), but the rear seems loose (it slides when cornering), it's not THAT bad but would like to fix that too if possible, like I said I think I need more rear traction, right??? What do you recommend?<<--??
Intelligentsia, I had the same problem with my TC3 a looong time ago, everything was set(ride height and droop) but when put on a tweak station it would be waaaay off.
So I think you should take out all the droop screws (or loosen them completely) and set the ride height. Then put your car on the tweak station and see if it's OK. Then set the droop and check again. By not doing everything at the same time and THEN putting it on the tweak station, you can check to make sure that the suspension is not binding or something else is wrong, so just go step-by-step.
#6852
Loose on exit; try added more rear toe-in, or if the car is rolling over on the rear while exiting, try added more rear spring.
Loose entering & thoughout; change the rear hub from offset to standard.
But the other guys might have a better suggestion then these....
#6854
it's loose entering; it starts to slide when I start to turn
i will try standard hubs again, but what about changing the rear roll-center to the high position?
Brant
#6855
tc3, as Pooky posted, the offset rear hubs are designed to "free up" the back of the car, so it will feel looser on all tracks. The only time this is good is on carpet when the car is too hooked up........Changing roll centers will only mask the problem if it works at all and most likely make for some odd tire wear or other problems, since it would need to be extreme to help..........Jim
