Team Losi JRXS
#242
Doesn't look like there's a whole lot of room for battery bars or orion plugson either side. I hate hard wiring so i use the orion plugs. Hmmmm. maybe if I had the car i would connect my batteries on the side opposite the rear pulley......
Oh I dunno .....I wonder how the Team is doing it
#243
I got the Horizon Tork mag in the mail today, and the new xxxs (sport) is in it. it is called the xxxs sport RTR 2 and its due in december. Price:270.00.
#244
Originally posted by HarshGuy
Todd, if during this testing process you are in need of test marketing the car to middle aged grumpy guys with no driving skill ...I'd be willing to help out, just lmk
#245
Originally posted by Cobra81li200
There's no TORQUE STEER on a belt driven car. The problem on the pro3 came from the big difference in length of the two diff halves, the long one was twisting under power giving a tendancy to go on one side. Looks like the same problem may occur here.
That's why most higher-perf FWD cars use a bearing-supported halfshaft to allow the use of equal-length drive axles.
The Pro 3 has equal-length axles...so any "torque steer" didn't come from that.
#247
Torque steer comes from the torque applied by the motor on the chassis when you acelerate. On a shaft driven car the motor lifts the left side of the car, thus there's more pressure on the right tires than on the left ones, resulting in a difference in grip and thus resulting in the car drifting to the left side.
A comparable effect could be seen on the pro3 as the diff halves were of very different sizes and out of plastic, when torque was applied on the diff pulley by the belt, one outdrive would twist much more than the other, resulting in a difference in time response to acceleration on the left and right wheel.
I don't know what you tried to explain, didn't understand what you're talking about.
#248
The only touring car I ever seen with "equal" length diff halves was the.....XXX-S.
#249
Originally posted by Keith Billanti
TC3/4 have different legnth diff halfs
so did the
yokomo mr4tc/ yr4/ yz10/ mx4
so did the
#250
#251
#252
OOPS..forgot about that Kyosho KX-ONE and the older Schumacher AXIS cars. lol
#253
What about the mission 1 and 2, the assassin, robitronic, PTI, Kawada, etc, etc ?
#254
true, but on the pro3 the difference was massive and you could actually twist the longer outdrive with your own hands, thing that can not be done with the cars you mentioned.
you claim that it is because of the size, when in fact it is because HPI's are junk.
TC3 had some tourque steer due to the rotation of the motor and poor balance. Not because its diff had different size outdrives.
