Like Tree18Likes
Old 10-26-2006, 02:51 PM   #8806
AM03GT's Avatar
Originally Posted by cheech4
hey all im running into a problem i have a RTR TC4 i just upgraded the plastic outdrive to metal one, i got the diff rings and the out drives did the switcharoo. But when i put it all together the rear diff dont spin the tires just stays there and the front spin. I think my diff is too loose but i thought i tightened it really good. it seemd like the second i put in the ground to go the diff got loose, how do i keep the diff screw from getting loose, how do i keep the diff tight.
make sure you didnt strip out the t-nut...
Associated // Reedy // Radiopost // XP Digital // Parma PSE // Integy
AM03GT is offline   Reply With Quote
Old 10-26-2006, 05:25 PM   #8807
ford_racing's Avatar
Send a message via MSN to ford_racing
And you do have to build the steel diff differently to the plastic ones, else it will not work
ARC R11
Yokomo YRF001
AE B5m
ford_racing is offline   Reply With Quote
Old 10-26-2006, 05:47 PM   #8808
well this is the first time im upgrading to the stell diff on this car so if you so kindly would explain what you mean by what you said??
DTX Evader ST Pro Brushless, Tx Mini E-Revo VXL
cheech4 is offline   Reply With Quote
Old 10-26-2006, 06:15 PM   #8809
offroader's Avatar
Trader Rating: 15 (100%+)
the metal diff requires a differetn diff bolt than the plastic one. It is # 6575, and includes the Tnut u will need
You cannot use the bolt suppleid with the plastic diff as you cannot tighten the diff together.
offroader is offline   Reply With Quote
Old 10-26-2006, 06:35 PM   #8810
i know i have the different bolt and the tnut. my problem is when i put it down and started driving only the front wheels were spinning so my guess was my rear diff came loose. i would like to know if someone here knows how to keep it from getting loose.
Old 10-28-2006, 05:26 AM   #8811
volracer's Avatar
Send a message via ICQ to volracer
Default Steering slop
I have read in th is forum about the slop in the steering of a TC4. Does anyone know where/what page it was on? Has anyone tried to turn the servo, so it faces down like on some 1/8 scale on road cars. This would have the servo horn on the same plane as the steering mechanism; thus the servo would not be pulling up and pushing down on the steering mechanism.
volracer is offline   Reply With Quote
Old 10-28-2006, 07:47 AM   #8812
WinnipegRacer's Avatar
What is the gear ratio of the diffs in a FTTC4?
WinnipegRacer is offline   Reply With Quote
Old 10-28-2006, 08:10 AM   #8813
adamge's Avatar
vol, you may have read my post. I'm not happy with the slop in my FT TC4's steering. It somewhat defeats the purpose of buying a $130 digital servo.
You are correct, the slop is because the steering hub connection is much lower than the servo arm connection. The servo is forcing that hub up and down, and there is a lot of slop movement before the hub can generate force up and down. And yes, the fix is to mount the servo higher (detrimental to pretty much everything) or rotate its mounting orientation to a vertical one (detrimental to pretty much everything).
Since neither of these is a good and easy fix, I'm just going to buy a different car. I've got my eye on the T2'007. It's amazing how spending another $100 gets me a car that is leaps ahead of the FT TC4.
When someone is intent on excelling in an otherwise laudable manner, does he not desire to inflict pain on others by means of his exalted status and enjoy the envy he arouses? Is there not an anticipated delight in an artist's ability to defeat his artistic rivals, which heightens his euphoria in creation?
-Nietzsche
adamge is offline   Reply With Quote
Old 10-28-2006, 08:40 AM   #8814
volracer's Avatar
Adamge,
Thanks for the info. Good luck with the 007. I use my TC4 for a club Johnson silver can class. I have a T1 FK05, I bought used. It is a nice car.
Old 10-28-2006, 03:15 PM   #8815
what tires do you guys use for racing
mattster is offline   Reply With Quote
Old 10-28-2006, 08:10 PM   #8816
hey what tires do you guys use for racing
Old 10-30-2006, 12:38 PM   #8817
AM03GT's Avatar
tires are very track dependent... best bet would be to askt he local club guys where you race for tire advice... if you want a ballpark suggestion then reply here with a descripion of the track conditions, relative traction level, and track size...
Old 11-05-2006, 12:17 AM   #8818
DaveW's Avatar
Hey guys, i busted the tub car out of the closet for some laps on the rug this weekend... with a few changes to it. I mounted the rear shocks on the front of the rear tower... similar to the RDX... it handled pretty decent. It transferred weight much faster and tweaked out easier than before. Im gonna make some custom inner camber link mounts for the ballstuds during the week. Ill post some pics up late tomorrow of my progress so far.
DaveW is offline   Reply With Quote
Old 11-05-2006, 12:22 AM   #8819
DaveW's Avatar
Try a few small rubber bands... sounds ghetto, but it is quite effective for reducing slop in the steering.
Old 11-05-2006, 04:28 AM   #8820
wyd
Tech Legend
wyd's Avatar
Trader Rating: 48 (100%+)
Send a message via AIM to wyd
Dave cool to see your still running some. Frederick and the asphalt are calling you.
Castle Creations (Since 2005)
Bumps & Jumps RC (One of the best racing facilities around)
ST Racing Concepts (STRC) Great aluminum upgrades for many brands.
Custom Works (Best Oval Cars around). Too many titles to list
Shout out to: Sticky Kicks, CR Graphics and Race Ready Products
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 07:11 PM
BATTERIES - Team Orion 4200 SHO Team Cells (6 cell) packs................... For Sale 2-Bad Australia For Sale/Trade 0 03-21-2008 01:16 AM
New Items for Sale Tamiya F103gt Chassis Kit, Team Much More CTX-D, Novak, Team Orion Tsquare R/C Items: For Sale/Trade 14 04-17-2007 07:29 PM
>>> BRAND STINKING NEW NEVER RAN TEAM JAMMIN FACTORY TEAM FTE RACING BUGGY <<<< mach51 R/C Items: For Sale/Trade 5 01-25-2007 08:13 PM
F/S Team Associated Factory Team RC18T with Mamba Comp X Brushless and Extras ZeroCool101 R/C Items: For Sale/Trade 7 01-07-2006 12:54 PM
