Team Associated TC4
#5356
the fins on the side of the heatsink do nothing for the motor cooling...for one they are the wrong way around (fins should go length ways so the air can flow through them)
and cutting them off, allows more air flow around the motor and it actually aids cooling more than the heatsinks (i have a motor mount the same as gaz's..and gaz actually did it for me) and i have noticed a decrease in motor temperature
#5357
hey m8
on the tub chassis there will be less air flow to the motor mount so it may get hotter.but the twin deck chassis lets more airflow through the car,plus i have 2 much more cooling fans on the car now
anyway the cooling veins in the motor mount run vertical and for optimum cooling they would run horizontal to let cool air flow through it more swiftly
i cant think of another car with such a heafty motor mount
even though my motor mount as been made smaller ive now made more surface area for the cool air from the fans to get too
cheers gaz
ps thanks for the setup advice stephensobottka
cheers gaz
#5358
o thats kool thanks ill look into one
id just like to say thanks to all the guys in this forum for being really helpful especially wyd, raving monkey and gaz8 thanks guys
#5359
Tech Legend
Trader Rating: 51 (100%+)
For driveshafts the Team Bomber graphite one is one of the nicest I have seen. Speedtech has them and you can see what they look like. Kinda pricey but everything in this hobby is.
#5360
except your lovely trophy gals..which you get for free
yokomo also make a CF shaft for the TC4, but i heard it doesn't hold up to well in modified but is fine for stock and 19t.
#5361
you could say that again
ive seen the bomber one just wondering if they were any betterones. monkey ill look at that one cause right now all i run is 19 and stock but next year i would like to race mod at another track by me but thanx anyway
#5362
I saw this picture in the Reedy Race Asia thread..
Is that lower diff case half aluminum? Is is already available?
#5363
-Dave
#5364
thanks dave. I'll be waiting for your news at the stinger thread.
#5365
if you want some alu diff cases...search RD logics on ebay, they make some..i think they come in blue or red...about $30 for 1 diff case (upper and lower)
#5367
is titanium stronger and lighter than steel?
#5368
a decent Ti will be as strong, or just a tiny bit weaker than steel but as light (or a tad heavier) than alluminium
#5369
Has anyone tried the Yokomo low friction shocks on thier TC4? Looking at pics from the Reedy it seems a few of the racers have tried them. Wondering how they fit, and which they are using (they come in Long and Short sizes) Also, how do they compare to the TRF Dampers?
#5370
Titanium is stronger than steel and lighter,Titanium is also more brittle than steel,steel will bend and for the most part Titanium will break.Titanium is also stronger than Aluminum but Aluminum is lighter.Titanium cost more because it's alot harder to work with than Aluminum.
