Team Associated TC4
#4591
well the tc4 is my first touring car. well first impresions after building it wasnt that good due to the amount of slop i found in the car.
after i shimmed it up better i was much happier!
i was totally amazed with the car at my first every touring car race it was an indoor carpet track,i went on to win the b final and came home a very happy man.
ive fitted many hop ups now and the car is amazing !!
i just need more track time now and i,ll be up there with the big boys!!
i love my tc4 and im very happy i bought the car.
cheers gaz
cheers gaz
#4592
gaz, are you from the UK?
by looking at some of your other posts you sound like someone i know that races a tc4.
you don't race at a club called GTCC by any chance do you?
#4593
hey me old mucker !!
thats right its me (chunkymonkey)
i must apologise for saturday night as i was spitting feathers!!!!!
id made a big mistake in not noticing i had a bent hinge pin and a crack in my wishbone when i set the car up on the hudy.
so when i put the new bits in i was struggling to get the car back on track!!
well matt what motors have you been running in the spec class??
and what gearing did you use on saturday night??
cheers gaz
cheers gaz
#4594
thats bad luck dude...hope it goes better next time.
i am running a team br00d C2 (email [email protected] if you want one) and the gearing i am running is 72/25.
speed is about average down the straight but through the corners it has loads of rip....it is unfortunate that you run rubbers and i run foam because i could of given you a fairly good setup
#4595
hey matt
i ran the same gearing but ive been using a putnan exessive force and it seems a good quick motor!
but ive also read that eddie at team brood makes damn quick motors too!!!
are you at batley next weekend??
#4596
probably not....i finish work at 5 so it would be a rush to get to batley (takes about 20-30 mins depending on traffic)
is the putnam a 2mag or 4?
i have never driven a faster 19t than my br00d....its unbelievable...saying that i haven't tried putna, team scream, EA or anything..just br00d in 19t.
but i will be trying an EA atlas based 19t when he gets them in.
#4597
my putnam is the 2 mag trinty chameleon !!
where did you get your team brood from??
#4598
Colin at c-sracing (he is the distributor for them in this country)
email [email protected] or go post in the C-S RACING THREAD on there (in this section)
#4599
ok maybe i just missed it on the bmi site but how much is the tc4 setup and do i need anything else once i buy it (other than the tc4 i already have) to finish it?
#4600
its $125 and iirc you don't need anything apart from the tc4 kit (obviously)
#4601
thanks for the reply.
#4602
Re: link
Originally posted by crACkeD ChaSsiS
that link doesnt work. i wanna get a look at some of those tires!!
Here you go. You can also see them in the new car action mag. Thay used them on the jrxs car when thay tested it.
#4603
Mornin all,
I've just converted over to the full graphite component set for the car, and I was wondering what difference it will make to the car in terms of driving. I had the car pretty dialled with the composite, so I'm hoping this will just finnish it off.
Cheers
Crashmaster
Cheers
Crashmaster
#4605
Originally posted by Charles Godwin
It should also maybe make the car more responsive
