charger not charging?
I have the yokomo bcs charger and my batteries wont even get up to 1.60 volts, i just got a promatch pack and the labels are 1.69 and dosent even get past 1.60. I got around 1.60 with my old fukuyama packs on my old dynamite peak plus charger. I set my setting to peakcharge, temp 59, 5 amp, 4500mah (i even turned it all the way up to 9999), cut of v to 23v and mv to 50. I have the cosel 13amp power supply, could it be because of that? The charger also has yokomo charge (pulse charge) and temp charge. Any ideas????
Umm, that doesn't sound right, try 3300 mAH, 5 amp, 4mV per cell,
Doesn't matter, if you batteries are 3300s then set the mAH rating at 3300. 4mV per cell is 24mV per pack.
Yeah, if your pack is rated at 3300mAh, set your charger at 3300mAh. 5.0 amps sounds good and 24mv per pack sounds good also.
The power supply doesn't matter. Just make sure you charge within the limits of the power supply.
nick51: as i said in the fukuyama thread your individual cells should not be getting up to 1.6v (as i understand it you are talking about the voltage of individual cells not the pack as a whole?)
i think you will find that the labels on the promatch pack are actually 1.169, not 1.69... besides, that is average discharge voltage, not peak voltage
ideal peak voltage for the pack is about 9v
try charging at 5-6amps, peak start with 30mv for the whole pack and see how that goes, also temp should be at about 63 i think... however i'm not too familiar with the yok chargers so these settings might be a bit off
wency, domo, azndrag: i think the yokomo charger settings are such that if you set it to 3300mah it will cut off at that level, unlike other chargers where the mah setting doesn't affect the actual charging (correct me if i'm wrong)
if you have a seperate voltmeter you can use that to measure the voltage across individual cells but you shouldn't need to unless you think you have a dead cell... as long as all the cells are healthy they will read pretty similar voltages
the voltage number on the screen during charging is the actual pack voltage at that time. doesn't really mean anything much during charging, but you want the peak voltage to be at about 9v (this the voltage when the charge ends, but NOT after it ends, that will usually be about 7.3)
hope that helps
hope that helps
hope that helps
hope that helps
The labels on the cell are DISCHARGE voltages.
The voltage your pack reaches under CHARGE is essentially meaningless*.
As long as the batteries are getting a full charge, you don't need to worry.
(*peak voltage can be an indication of the internal resistance of a cell, when a pack you have starts to peak at a higher voltage, it's a sign that it's resistance is increasing, this will decrease punch - it's only a sign though, don't assume that your best packs have the lowest peak voltage.)
