Ko Propo VFS-1 ESC
#2491
Twister 2.0
Dear all, i have a Twister 2.0 which is intalled on my old trust worthy HPI Pro 4 which i am converting for drift.
Would really love to run Lipo, is it possible and how about the Lipo auto cutoff can the ESC be updated?
#2493
Make your life easy...pick up one of the Novak Smart-Stop units. Now they're even better than before because they're good one- to four-cell with auto-detect where before you had to buy a two-cell unit or a three cell unit specifically. Reasonably priced and pretty dead-nuts reliable.
#2494
Capacitors Needed?
I have two of these ESCs(KO Propo VFS-1 item # 40051).
-Does anyone know if Capacitors are needed to be installed on this ESC?
Thank You
Thank You
#2496
you can see the stock one on the left (and the schottky diode on the right)
#2497
KO PROPO VFS-1 Brushless ESC
Thanks for the info Big B and cplus.
I should've mentioned that the KO Propo VFS-1 (item # 40051) in question for Capacitors; is the Brushless ESC.
Thank You
Thank You
#2498
The VFS-1 does benefit with running a capacitor and any of the new ones will work with it. Helps the brakes and the punch.
#2499
#2500
Thanks for the info Johnny Wishbone and cplus.
(Johnny Wishbone. Do you run Capacitors on your ESC?)
I believe the latest VFS-1 (item # 40052) comes with Capacitors.
- so it's safe to say Capacitors will improve the performance of the older VFS-1 ESC (item # 40051).
I will install the capacitors and try it.
#2501
Does anyone know what is the stock Cut-Off Voltage setting on the ESC?
-Ni-MH or Li-Po?
Thank You
-Ni-MH or Li-Po?
Thank You
#2502
NiMH, clearly. so it will kill your LiPO...
#2503
Thanks for the info; Airwave.
I have to change the Cut-Off Voltage to prevent damage to my Li-Po battery.
-the only way to change the Cut-Off Voltage is through a computer?
-or; is there another way to do the changes?
Thank You
