LRP SXX StockSpec V2 ESC
#961
I'm just not happy with running glitch buster or adding an external BEC. Cheers,
#964
not much difference from the previous one.
#965
Looking for some help and couldn't find the specifics in previous posts. I am getting ready to use this ESC with a Thunder Power Z3R 17.5. what are some good starting points when looking at small asphalt tracks? My son currently runs a Hobywing Xerun 60A and a Tekin 17.5 with an FDR of 3.53 (39/69) and temps ~150f (no fan) after a 7 min run. Used to relying on a laptop so the configuration on the LRP is new to me. We run the blinky - non-boosted class. Thanks in advance!
#966
I hate to say it guys but im leaving LRP.... im tired of the esc dying on me... this will be the second time and its frustrating that my $68 esc performs better then my $220 esc!!! It just stopped working on me in the middle of qualifier on a track made for short course and 10 scale.... i am truly disappointed in the product! Just being truthful!!
#969
The ESC says "LRP" on the top. J/K
but seriously:
What defcone says is right. If it is failing, a way to test the BEC it is to plug a receiver pack into the battery port on the receiver and test again. If it works with the receiver pack and not without it then the BEC is bad.
but seriously:
#970
but seriously:
but seriously:
Mines working and Im using it atm and it seems to me there is no problem, but I heard that it could be bust.
Im thinking not as its all working
#971
If it aint broke dont fix it.
If the ESC is working and you see no problems then I would say its fine.
If you do have problems with it shutting off at full power or not turning on the receiver then the BEC could be bad.
If you have the above symptoms then the test with the receiver pack would tell you if its the BEC that is the problem.
#974
The LRP is my first brushless ESC for 1/10 car and I like the way it works. I was just bummed that it stopped the first time I ran it.
I bought a replacement to hold me over when mine initially failed. I think the guy I bought it from had already had it replaced by LRP.
So far both are working nicely (knock on wood). I would'nt listen to your buddies when clearly yours is working fine. Go out there and woop up on em on the race track!!
#975
So I'm assuming my BEC is blown on my stock spec V2 when plug in to my receiver it won't power up but when i unplug it was fine..Can I just bypass it and just hook and a receiver pack to power up my servo... I was thinking if I can getaway with the receiver pack might as well just use on my 1/12 scale any thought?
