who holds the speed record?
#676
There would be more air under a 1/10. A micro has a lower ride hieght too. And my wing is huge, not suposed to be used for speed runs, but I haven't got around to making a new one.
#677
tyhere is also more surface area. meaning more downforce.. so a micro wil have less surface for downforce...
how high is your chassis of the ground??? ill tellu if it is lower then a pan speed car....
if your to low remeber u might want to raise it.. every little rock or bump u hit is going to upset the car bad..
10th scale or 1/18th scale stuill forces through the same air.. it just moves and usses more or less of it..
#678
#681
Originally posted by ajg
I just made another video of it hitting 60mph, then crashing. I'll post pics of the damage and the video later.
So, how did you wreck it?
Pebble?
Uneven road surface?
Radio range?
...........................had to have been something, you shouldn't have wrecked.
You still need to fire your cameraman.......or unless something else is going on here........
#682
Originally posted by GundamWZero
You wrecked the car!!!! AND took damage!!!! Thought you said the road was clean? Told you parts break at any speed. If you could drive, you wouldn't have wrecked.........
Pebble?
Radio range?
Pebble?
Radio range?
#683
Here's the link again: http://www.one18th.com/showtoy.php?id=3078
You can see all the damage in the first pic.
Video: http://www.one18th.com/showtoy.php?id=3076 or http://www.one18th.com/showtoy.php?id=3077
Which ever one works.
#684
I'm using the vsm till I hit higher speeds, then I'll get a radar gun. The vsm is about 2mph off while radar is 1+mph off. So for now it is accurate. But probably not for the higher speeds. The test for the vsm was done by xtreme rc mag.
I sugges you go and get a speed gun, (best place to borrow one, call around to local little league baseball teams, some have speed guns for pitchers) then measure TRUE speed. I'm guessing you're off by about 20mph right now.
Then again, sounds like you bashed the car up. Perhaps some driving lessons before trying again?
#685
Yeah, when it glitches once your just a horrible driver. Also, I can tell when I get tire spin, and I stop that run and try again. Your guess is about 20mph off, so stop guessing, because I have proof for that run(and the most of the other runs).
#686
this guy has an answer for everything we call him on... thats why u know he is lying... he is always right.. and everytime we come up with a FACT that he isnt doing, he says oh i do that.. with your power to weight ratio, u will have tire spin on every run...
every time u hit a bump and the rear end jumps it free spins.. that also will change the speed... but u prolly can see the rear lift when it is going suposedly 60mph and u stop and run it over right???? i guess we can just answer our own questions... from now on. cause we know your answers..
#688
A. camera on tri-pod
B. Speed gun measuring your car
C. Speed gun's meter viewable from video captured from item A.
And how do you know when you get a tire spin at say 200ft away? your micro looks like blurry dot at that distance? Or are you driving with binoculars? Or does your radio have some sort of traction feed back feature, like a real car's gas pedal?
Take a hint from Cliff Lett's speed run car. He mounted his receiver on the front bumper of his car. Getting his radio equiptment FAR away from his electronics. With rat's nest of wiring in your car, I'm surprised your AM radio doesn't glitch even more than it did.
Like you said, you spent $1100 on this project, you figure a GOOD radio would be high on that list.
#690
Re: who holds the speed record?
Originally posted by dracy69
What holds the speed record, nitro or electric?
It's Cliff Lett: 111 mph...........
For TCs, again Cliff Lett: 98.4 mph.........
Took a while for it huh?
.............now back to The Eternal Flame, starring AJG............
