who holds the speed record?
#661
i also talk t a guy from rc driver.. he said some guys in cali were doing speed runs with micros.. upwards of 40+.. he said all of them had major problems keeping the foam n the rims...
they tried every kind they could get.. and the foam still exploded off....
also lift off was a problem to....
#662
Originally posted by burbs
how do u know it hit 60mph in the vid?? do u have a radar gun yet????
these speed guesses just dont cut it
#663
New video, again I don't know if it loaded properly. http://www.one18th.com/showtoy.php?id=3076
#664
can u post some pics up close of your mini??? i want to see how u have the speed meter hooked up.. i also looked on there site..
how did u calibrate it to your car???
it says u need to do this to get accurate reedings... in order to calibrate it u need a correct speed to start with.. right???? how did u test the initial speed...
and please post pics not vids of how it is hooked up on your mini
lifiting has nothing to do with down force...
lifting occours when to much air gets under the chassis.. and causes lift.. no body can keep air from under the chassis.. thats why 10th scales lifted
#665
Alright, I'll get some. Also, I recalibrate it as the tires wear, so it always gets an accurate reading.
#668
and why dont any of your vids work properly???
how did u do the first calibration to make it read accurate????
Also to calibrate the vsm, you need to mount the magnet (I drilled a hole in the h-hub about half the depth of the magnet, and glued the magnet in it.), the you need to mount the sensor no more than 3mm away from the magnet (mine is 1.5 to 2mm away). You then align the magnet with the sensor, and roll the car till the magnet makes one full rotation. Then you look at the ruler that sould be sitting next to the car and see how far it took to do one full rotation.
I know tires wear and you loose speed, that's why I recalibrate it often.
#670
http://www.one18th.com/showtoy.php?id=3078
I'll try to get one after the run too. It's dark now so I can't do it now.
#671
PRS now makes a 60 toth pinion... if u want top speed thats what u should run.. 1 to 1 ratio..... there like 5 bucks
www.lefthander-rc.com has them in stock
#672
Too bad they won't fit on my car.
I'd get them if they would, and if my motor could even move the car.
#673
burbs.....
lifting has everything to do with downforce. There will always be air under the chassis, but as long as the downforce is greater, then the "UP" force, lifting won't occur. Downforce and "lifting are just two forces working against each other. They are directly related.
#674
Originally posted by Bodido
burbs.....
burbs.....
#675
im sorry if i didnt state if properly... with the size of the car and the amount of under chassis air, the downforce at that speed will not be great enough......
10th scale speed cars. have super high downforce bodies.. 2 wings.. and alot more weight and surface area keeping them planted... yet at a certain speed it still gives out....
all it take is one unsteady gust and it goes up..
