Team Corally RDX Touring Car
#9766
Originally Posted by syndr0me
Jeff said he's working on getting some new setups on the site, so hopefully we'll see them soon.
What springs are you running in the rear? A lot of the setups on the site now have really soft springs, like 17lbs. I've gone all the way up to 24, and it's freed up the rear of the car tremendously. I noticed in Jeff Cuffs' latest setup, he's using 24's too, so maybe there's something to it.
#9767
Zing! It's possible I might have deserved that.
You did deserve that.....
#9769
I have more I am working on. Just too much going on during the Holidays.
Jeff
#9771
Originally Posted by jeff jenkins
hey everyone.. what are you guys doing to make 28mm foams work on this car.. they hit the spring retianers and when i turn my end-points down i just dont have the desired steering that i am looking for.. or is everyone using 26mm foams for mod.
#9772
Jeff
#9774
hey
does anyone have a good rubber setup?
brian mcgreevy if you ever tryed rubber would you give me the setup you had if you remember it?
Thanks Josh
Thanks Josh
#9776
Originally Posted by Electro-MAX RC
so where do these new parts go? can anyone post pics of them on the car?
thanks!
thanks!
#9777
Gee, that is such a pretty shade of pink....
#9778
I'm using a carbon edition Orion Lipo in my RDX, but the top deck doesn't make plugging the battery in very easy. Do you guys suggest modifying the top deck, or using some different tabs on a set of bullets?
Syndrome don't you run the carbon battery in our BL lipo class? How do you have the battery set up in it?
#9779
Originally Posted by ccs77
ISyndrome don't you run the carbon battery in our BL lipo class? How do you have the battery set up in it?
To keep the battery from sliding around, I glued some thick rubber o-rings to the chassis that won't obstruct the belt, and will prevent the battery from sliding in toward the center of the car.
Corally's team driver Brad Johnson was at our track all weekend, spreading the RDX knowledge. Cool guy, and very helpful. I learned, among other things, that I have a lot to learn. :-) And that I'm infamous!
#9780
I'll try soldering the wire into the bullett connector differently. Are there bullets with 45 degree angle tabs that would make it easier?
