Team Corally RDX Touring Car
#4936
Originally Posted by Greg Anthony
We're gonna miss ya at Novak... you could show Barry what a whitewash is!
Jeff
#4937
Ordered a 4mm chassis from Specialzed R/C 2 weeks ago. How slow are they to ship stuff out?
#4938
That is a popular item and more than likely they were out of stock on it when it was ordered and they are waiting for a new supply of chassis. But also remember that if you ordered it 2 weeks ago, it could have gotten momentarily lost with all the holiday shipping. This time of year creates a mess for shipping. Either way I would call Corally in the morning! They'll be glad to help you out!
#4939
Hey guys, I need some help selecting a RDX chassis. I want to primarily race it on a carpet road course with rubber tires, but would also like to have the ability race it on a carpet road course with foams. Can i get some input as to which RDX kit to buy (US or UK) and if i need a seperate chassis for each. Any help would be greatly appreciated.
#4940
Carpet Spec
#4941
Carpet spec...for sure!
#4942
Get a carpet spec, and grab a front one way, and the black spring set for rubber tire racing as well. The thicker upper deck helps a bit. The stock main chassis is great for almost anything. The 4 deg caster blocks that come with the carpet spec kit are a good medium for anything as well.
-Korey
-Korey
#4943
question. i was puting together my kit last night, and had a hard time getting the bearings on the main gear shaft. i basically had to beat the shaft through and now the bearings seem tight. also the rubber o ring was a no go with the tight bearing. what should i do?
#4944
Originally Posted by HarshGuy
You mean RDX-Bill, not JRX-S Bill...
Matt Howard sent me his setup!
#4945
Just built my new kit. Everything went great. One question..
There were several 3mm aluminum spacers included but were not used per the instructions. What are they for?
Thanks.
Thanks.
#4946
I still haven't answered that question myself . The only thing I can think of is putting them behind the bottom shock ends if you run the arms full back front and rear as changing the wheelbase changes the angle of the shocks.
I use them for armature spacers on my lathe...
#4947
i noticed after puting my kit together that the rear camer turnbuck is very close to the shock. is this normal?
#4948
-Shookie <><
#4949
Thanks.
Thanks.
#4950
Jeff
