Set-up Stuff
Set-up Stuff
I was at one of my local tracks this past weekend and saw one of the nitro guys with some weird but cool looking wheels on his car as he was setting it up. They were thin and aluminum with a thin rubber strip in the center of them. They looked like they were something off of a top fuel dragster. Anybody know where I can get these wheels to set up my rig?
- JayBee
- JayBee
Yokomo makes some. They're for setting up your car.
You can get them at Speedtech RC ( www.speedtechrc.com )
also take off do a set, take off make the CS tyre range. im not sure if you can get them over in the states, but they are the same price as the yokomo ones over here in the U.K.
J-P
J-P
So do HPI and others
Do they make your camber measurements any more accurate?
Also, what is the best way to measure toe in/ out on the front wheels with out spending hundreds on a hudy setup system?
Originally posted by Blakesrc
Azenis, I believe rpm makes a tow guage that is only about 15 dollars.
Blake
Blake
It is meant for trucks and buggies with a wider track, I think.
I use the board to set toe and I don't seem to have any probs.
Oh, and RPM camber gauge is fine, but you have to file off the rounded bottom part of the body to be flat with the moveable part or else you will get false readings.
It is fine once you do that, but only with setup wheels, of course.
cool
will see if i can track one down, where do you buy integy stuff? in australia?
Originally posted by MrRolla
Your better off buying it at integy's homepage, you will pay through the roof for it in Oz.....
*puts flame suit on so the purists dont attack me for not supporting the LHS*
On ebay for $69.99
On ebay for $69.99
