Viper R/C Solutions - A New Line of Innovative Power systems!
#811
1. Open Viper PC-Link program.
2. Click “File…” button on left side of Viper PC-Link Console and select the firmware upgrade file you wish to update to.
3. Connect PC-Link Cable to USB port.
4. Click the dropdown menu in the upper right corner of the Viper PC-Link Console and select the appropriate USB/COM port.
5. Connect proper/charged battery to ESC and power on ESC (Radio can be on or off).
6. Push V-Port on/off button once to enter programming mode. F and N status LEDs will activate to indicate programming mode.
7. Connect PC-Link Cable to V-Port jack. ESC current firmware version will now be indicated at the top of the Viper PC-Link Console.
8. Click “Download” button on left side of Viper PC-Link Console.
9. Wait for status indicator window at bottom of Console to say “completed”, green download bar will be solid, and new firmware version will be indicated at the top of the Viper PC-Link Console.
10. Disconnect PC-Link Cable from V-Port, all LEDs will cycle.
11. Turn off ESC.
12. Redo ESC radio calibration process after updating firmware (see ESC instruction manual).
13. Firmware update complete!
Hope this helps.
#812
Yep, it's porpuse is to give the amount of slop needed in the rotor inside the can. without her it's impossible to run it.
#814
sorry to contradict you but could not run fine or we are not talking about the same spring.
#818
#822
Here is a quick vid on what can be changed with the proguage.
http://www.youtube.com/watch?v=AcrSo..._order&list=UL
Rex
Rex
#823
Eric
#825
Hi Jay,
The VTX1 is already available.
http://viper-rc.com/vtx1.html
"The VTX1 is designed for 1/12 and 1/10 scale on road applications without a radio receiver pack"
