Go Back   R/C Tech Forums > General Forums > Radio and Electronics
Old 12-27-2011, 02:54 AM   #811
Originally Posted by 4wheeldrive View Post
I downloaded the newest viper update and the instructions say to open up the .rar file but the file for version A30 is a .vuf file. Am I missing something here? What do I do with the file now?
.rar is the pc-link software, wich now is .zip. To upgrade the newest firmware do like this:
1. Open Viper PC-Link program.
2. Click “File…” button on left side of Viper PC-Link Console and select the firmware upgrade file you wish to update to.
3. Connect PC-Link Cable to USB port.
4. Click the dropdown menu in the upper right corner of the Viper PC-Link Console and select the appropriate USB/COM port.
5. Connect proper/charged battery to ESC and power on ESC (Radio can be on or off).
6. Push V-Port on/off button once to enter programming mode. F and N status LEDs will activate to indicate programming mode.
7. Connect PC-Link Cable to V-Port jack. ESC current firmware version will now be indicated at the top of the Viper PC-Link Console.
8. Click “Download” button on left side of Viper PC-Link Console.
9. Wait for status indicator window at bottom of Console to say “completed”, green download bar will be solid, and new firmware version will be indicated at the top of the Viper PC-Link Console.
10. Disconnect PC-Link Cable from V-Port, all LEDs will cycle.
11. Turn off ESC.
12. Redo ESC radio calibration process after updating firmware (see ESC instruction manual).
13. Firmware update complete!
Hope this helps.
Team AME/ORCA
https://www.facebook.com/strawberryrcdesigns
http://www.strawberryrcdesigns.pt/
jorgesimes is offline   Reply With Quote
Old 12-27-2011, 02:57 AM   #812
Originally Posted by narcotiks View Post
managed to re solder the tiny black comonent, but i seeem to have lost the little spring that goes on the front end of the rotor. does this spring do anything imortant?
Yep, it's porpuse is to give the amount of slop needed in the rotor inside the can. without her it's impossible to run it.
Team AME/ORCA
Old 12-27-2011, 08:03 AM   #813
narcotiks's Avatar
Hmmm
Is it crucial ? I powered everything up and the motor ran fine :/ if it's completely necessary , is there a replacement I can find or use in Australia?
narcotiks is offline   Reply With Quote
Old 12-27-2011, 09:35 AM   #814
sorry to contradict you but could not run fine or we are not talking about the same spring.
Team AME/ORCA
Old 12-27-2011, 11:07 AM   #815
4wheeldrive's Avatar
Trader Rating: 22 (100%+)
Jorge, I got it now. I keep forgetting that the .rar file is actually the pc link! I had an old email that you sent me with the included file and now I got it squared away.
thanks
4wheeldrive is offline   Reply With Quote
Old 12-27-2011, 04:21 PM   #816
narcotiks's Avatar
No no its fine
I'm talking about the spring that is on the rotor (pinion side) underneath the front end bell?
So basically
I'm going to need a new motor ?
Old 12-27-2011, 04:25 PM   #817
narcotiks's Avatar
Oh and is it possible to order another spring ?
Old 12-27-2011, 04:45 PM   #818
Probably just a new rotor, but i will email to see if there's spring units because i don't have access to database.
Team AME/ORCA
Old 12-27-2011, 08:13 PM   #819
narcotiks's Avatar
Okay Thankyou
Old 12-29-2011, 02:42 PM   #820
ekim628's Avatar
We dont have the springs available seperately but you can always use shims to space the rotor.
Eric K.
/ Team Associated / Viper RC / Radiopost / Sweep Tires / Much-More Racing / RAL Designs / Parma USA
ekim628 is offline   Reply With Quote
Old 12-30-2011, 08:12 PM   #821
narcotiks's Avatar
What shims would I need and how many to space the rotor correctly?
Does the rotor have to stay completely still in forward /backward movement while rotating ?"
Old 01-01-2012, 12:45 AM   #822
22Racer's Avatar
Trader Rating: 67 (100%+)
Here is a quick vid on what can be changed with the proguage.
http://www.youtube.com/watch?v=AcrSo..._order&list=UL
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail [email protected] Rex Welch
22Racer is offline   Reply With Quote
Old 01-03-2012, 12:08 PM   #823
ekim628's Avatar
3mm should be the right amount of spacing. The rotor should move about 1mm in either direction. You do not want to bind the rotor in the can or it will produce unnecessary friction. Let me know if that helps.
Eric
Eric K.
Old 01-03-2012, 12:20 PM   #824
JayBee's Avatar
Trader Rating: 31 (100%+)
Anything new in the 1s application department? Speedo wise....
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-03-2012, 01:14 PM   #825
Mário Ribeiro's Avatar
Send a message via MSN to Mário Ribeiro
Hi Jay,
The VTX1 is already available.
http://viper-rc.com/vtx1.html
"The VTX1 is designed for 1/12 and 1/10 scale on road applications without a radio receiver pack"
Viper R/C Solutions | Gens Ace | UMDEZ
http://www.viper-rc.com | http://www.umdez.com | http://www.gensace.com
Mário Ribeiro is offline   Reply With Quote
Viper RC - mini-dub Radio and Electronics 12069 12-04-2017 10:44 AM
