Old 02-04-2015, 10:06 PM   #3331
(0000000000)'s Avatar
I do.
Front: I put pink spacers under the bulkhead-side camber link until it is level with hub-side camber link.
Rear: the bulkhead-link is a little lower than level with the hub-link.
My Original USER ID was 0000000000. But now it doesn't seem to work.
(0000000000) is offline   Reply With Quote
Old 02-23-2015, 03:30 PM   #3332
sakura zero s carbon fibre chassis where can i find 1?
does any one have a battery strap mod for cf?
it really seems that they have discontinued this chasssis
some parts seem very hard to find
TeamThibault is offline   Reply With Quote
Old 02-23-2015, 03:33 PM   #3333
SteveM's Avatar
Trader Rating: 134 (100%+)
Hobbyking sells the Zero S re-branded as their own TD10 and you can get most parts from them.
SteveM is offline   Reply With Quote
Old 03-16-2015, 08:33 PM   #3334
I used the battery assembly from the Ultimate/XI and it works great..I thought that I could use the stock one that came with the kit but does not work with CF chassis
itselectri96950 is offline   Reply With Quote
Old 03-16-2015, 11:48 PM   #3335
3racing sells battery strap sets that work just got to drill 1 gole in the plastic part
heartostone is offline   Reply With Quote
Old 04-21-2015, 07:24 PM   #3336
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Anyone know if the Sakura XI Chassis set will work on the Zero?
OUT
Keith Billanti is offline   Reply With Quote
Old 04-22-2015, 07:16 AM   #3337
Not directly. The bulkhead and motor mount holes are slightly different. Can make it work with some drilling/countersinking. But you are still left with a bigger issue, which is how to mount the steering system. The steering system is one of the major changes between the Zero and XI.
Old 04-22-2015, 07:29 AM   #3338
Well that's dumb... lol
I am looking for a better (lipo) chassis option for the Zero. I acquired a pair of these for my daughters to run and one of them is bling'd out. Really nice car to be honest, and I have T4 15'. I just want a more idealized chassis.
OUT
Old 04-22-2015, 09:45 AM   #3339
There are a few different lipo chassis for the zero. But the steering system will always be that of the previous generation. Not a big deal though. The Zero S is still a very component car.
Old 05-01-2015, 09:34 PM   #3340
Jym73's Avatar
Hi,
I'm new on rctech.
I would like to know if the diff joint cup wear out fast on sakura zero s?
It seems that we can't find this spares anymore. Is there a diff cup from other brand who fit?
Jym73 is offline   Reply With Quote
Old 05-01-2015, 09:46 PM   #3341
Hi mate
No I haven't had that problem
Are you interested in the Sakura?
Cars: Sakura Zero S, Tamiya M05 Pro, Associated B4, HPI Firestorm Flux
davlind is offline   Reply With Quote
Old 05-01-2015, 09:49 PM   #3342
Diff cups wear out, it happens. The cheap way to fix it is to rebuild the diff and swap the left cup to the right side/ vice versa.
Old 05-01-2015, 11:01 PM   #3343
Jym73's Avatar
Thks.
Yes worn can't be avoid. Some brands wear out faster than other.
Yes i'm interested by the sakura. There is also diff. cup joint V2 still available but i have never used these plastic adaptater to put on dog bone, i don't know if it is strong enougth. I plan to use it with 9T brushless motor.
Old 05-02-2015, 08:40 AM   #3344
I tried them. They are aluminum and require the plastic "blade" to be attached to your dogbone/cvd.
I understand that this design is lighter and slightly less friction than the standard hard steel drivecups. But i do prefer the hard steel for durability.
Old 05-02-2015, 01:56 PM   #3345
Jym73's Avatar
Ok, thanks. I have never used aluminum drive cup, i didn't seen that it is aluminum.
I wonder if the hpi #109926 23.5x5mm heavy duty diff drive cup can fit in the sakura zero s diff. I use this ref. in an other brand's car and it has very good durability. It has an 5mm axle who has a little bit more than 11mm long with 2mm hole. It is for drive shaft with 2mm pin.
EDIT : i didn't seen, but rcmart seems sell SAK-S01A/HD who are already heavy duty. This part seems can fit in tamiya m05, m06.
1/8 : HPI Vorza - Tekno EB48.3 - H.King Rattler - DHK Optimus XL - BSR Berseker - FS Racing E9.5 1/10 : Wild Willy M38 - Tamiya egress original - JLB Racing truggy - Vkar bison - Turnigy sct 2WD - Basher RZ4 - BZ-444 - SST 1937 1/12 : WLtoys 12428 - Feiyue desert eagle - HBX Iron Hammer - HBX Thruster 1/16 : HuanQi 1/16 731 - RH 1/16 MT/SCT - BSR Bad Bug 1/18 : WLtoys K929 - XC Racing 1/24 : WLtoys A212 1/24
Sakura Zero - New Touring Car! InZane Electric On-Road 1355 02-14-2014 04:14 PM
New to the RC scene...need some help! Jmoney12 Rookie Zone 13 06-15-2010 09:21 AM
