"Challenge Formula One"
#151
#152
Now, has anyone had any dealings with the Cross F1? I know the car has great handling but the diff is not so reliable even though it's another 103 clone. It's not easy to set for the most part and seems to change the setting from time to time. Also, where can the front aluminum bulkhead be found since that seems to be a weak point for this car.
#153
#154
McLaren MP4/24
Have the McLaren MP4/24 hit tracks in the USA yet?
#156
#158
i agree... i feel its much easier to just replace the arms if they bend compared to replacing the center camber plate and all the hardware with it.
if you strengthen a particular part like the arms, it just means that the shock from the crash will just transfer to the next weak part... and that means probably the camber plate, the ball joints on it, and maybe even the mounts on the lower arm...
#159
Funny after posting that earlier I actually got knocked into a board in the first corner of the last race and the arm bent severely. So I grabbed the car, bent the arm straight and kept racing. Ended up 3rd. If it had been a stiffer part an broken I would have been out entirely.
#160
#161
#162
I agree I would rather have a part bend than break in most cases...however in this case the arm bends long before a stiffer arm would break. Think of it this way...when was the last time you saw a pan car break an upper arm without breaking a lower arm? Granted pan cars have a shorter upper arm and they are more protected by the body...but the difference isn't huge. Even if it were made out of a stronger material more prone to breakage I don't think you would be seeing many break. At the very least the material needs to be less bendy.
#164
who would be interested in having a three race series next year, east,west and texas? i can host the finals here in texas on the same track that the 200mm nitro sedan worlds was held this year. it is a HUGE track and 21.5 would be like watching paint dry but we can seperate into two classes formula one and GP3. we can adapt the TQ rules and regulations or i can come up with specs if need be. so i guess my main question is how many of you are actually willing to travel. me personally i can pull it off. we can even have a can-am GTP type class too just to have something different. the "challenge" site is the best way to organize this i think since its kind of a neutral meeting point with all of us. are there any can -am type bodies that would fit on a TC chassis with some deep offset wheels out there, not a "pan" car body but an actual real car? that would be neat!
