most powerful 1s?
most powerful 1s?
looking for some 1s batteries. i found fantom has 5400mah and 65c.
did anyone used it? it said max charge rate is upto6c. did anyone tried charge it by 6c?
also any recommendations for 1s? its for 1/10 and 1/12 pan cars
I have the lrp car comp line batteries as it says a mas of 3c charge rate but they also say a recommended charge rate of only 10 amps.
good luck with what ever you find and use.
Is there even a charger around that is capable of charging at that rate? 6C for that pack is like 30+ amps.
I just ordered 5 packs of 1S IP 5600 50C, just waiting for them to get stock the end of this month.
lipo and charger
Losi Xcelorin 3.7V 5600mAh 1S 60C LiPo is comming out mid dec.
Hyperion EOS0720iNET3 AC/DC Balance Charger up to 20amp charge rate.
http://www.losi.com/Products/Feature...rodID=LOSB9879
http://www.maxamps.com/EOS0720i-NET3-AC-DC.htm
So far I have only tried SMC and Epic. The Epic was a bit better as it fell off less and has lasted longer than the SMC. From observing other similar drivers to me with similar equipment, Thunderpower and CRC look to be a bit better. I really want to try the new IP this winter.
