Like Tree4Likes
Tamiya TRF417
Old 02-10-2011, 03:11 AM
  #691
Bad-Andy's Avatar
Anyone who was at the Snowbirds care to share their setup with us? I was told there was at least one 417 in the stock A-main.
Bad-Andy is offline
Old 02-10-2011, 08:06 PM
  #692
kschu's Avatar
Trader Rating: 16 (100%+)
I just tested roche Spool cup in my friend Trf416/417 Spool. they work without any problem. But i use 46mm bone for front.
Who likely to break the kits spool cup, can use it...
kschu is offline
Old 02-10-2011, 08:26 PM
  #693
jonest's Avatar
KS,
I'd like to try it out but I worry either the pin will break or corner entry would be stiffer (understeer). Btw, How much is it?
jonest is offline
Old 02-10-2011, 10:19 PM
  #694
kschu's Avatar
Originally Posted by jonest
KS,
so far i use it in my car never have pin break problem...
i dont know if it'll cause understeer or not ...
kschu is offline
Old 02-12-2011, 12:44 AM
  #695
What is the thickness of the 417 chassis? Do you think it is too soft?
ioxqq is offline
Old 02-12-2011, 02:20 PM
  #696
cyclone speed's Avatar
The thickness of the lower deck ( chassis ) is 2.25 mm i think.
Ok, I have a question please, im going racing tomorow, finished building my 417 a week ago, but what I dont get is the spacer on the front toe block ( 1C front, 1C rear ).
On most setup sheets I see 0.5 mm under the front 1C ( FF ) and the on the rear 1C ( FR ) I see 1mm. But in the instruction manual, when building my car, it says to put a 3 mm shim on the Front Rear 1C.
What am i suposed to do ? Im just trying to understand how does the spacer under the front toe block works .
cyclone speed is offline
Old 02-12-2011, 03:04 PM
  #697
veecee's Avatar
Trader Rating: 34 (100%+)
When the toe block is flipped at front-rear, the 3mm spacer gets it level with a non-flipped block. So 3mm on a flipped block is effectively 0mm.
veecee is offline
Old 02-13-2011, 01:41 AM
  #698
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
Exactly^ Rear block is flipped, causing need for spacer.
Jamison R is offline
Old 02-13-2011, 01:51 AM
  #699
chrisk's Avatar
Trader Rating: 32 (100%+)
What is the difference in height, if any with the split blocks?
Do you still run the same spacer under them at the front?
chrisk is offline
Old 02-13-2011, 02:22 AM
  #700
TryHard's Avatar
No difference to the standard blocks in height.
HiH
Ed
TryHard is offline
Old 02-13-2011, 02:40 AM
  #701
crabboy's Avatar
Trader Rating: 58 (98%+)
Had my first run with the 417 today and i must say it is better than the 416x.
i ran the standard kit set up and it worked great.
One think new we are running are the Roche spring retainers they are a bit larger in diameter than the Tamiya and work great with HPI springs.
Rhys
crabboy is offline
Old 02-13-2011, 05:16 AM
  #702
CHICO1977's Avatar
Rhys
Yes i agree i have been running the Roche retainers for quite some time now
CHICO1977 is offline
Old 02-13-2011, 05:45 AM
  #703
Hello,
Today I ran my TRF417 for the first time ( same as crabboy ), I must say that compared to my HB cyclone, it is MUCH nicer to drive and also easier to drive with a standar/comon setup.
Grip wise was very good, I had a tiny bit of traction rolling at the end of the last race but on the previous races, grip was very good.
My main problem was mid-corner steering... Initial steering was fine, exit was good but mid-corner steering was lacking. I had to slow down more to get the car around the curve. On-power mid corner steering was ok, but off power ( mainly during a hairpin ), mid-corner steering was missing.
-My question : how could I increase mid corner steering ?
-Side question : What is the difference between longer/shorter camber links ?
-Final question : Why are their more people using anti-dive in front these days ? What does it do ?
Thank you very much
Old 02-13-2011, 05:58 AM
  #704
Originally Posted by cyclone speed
Hello,
Thank you very much
I add one more question:
Why are almost all pro drivers are not using guards that prevent lipo is out of place? In all cars, Tamiya, Xray, Yokomo,...
TKS
WinDarK83 is offline
Old 02-13-2011, 07:16 AM
  #705
Vicko's Avatar
Trader Rating: 14 (100%+)
I also race my 417 yesturday,, TQ and won the spec stock class.
may even have set the fastest lap time for spec.. I drove the 416x then the
417 I set the 417 up just like the 416x and the 417 was easyer and faster
with the same body and tires.. This car only thing I need is less steering into an turn and more out of the turn on power. but the car is great to drive
Vicko is offline
