Tamiya TRF417
#5686
I started by using the stock v5 setup with:
- TRF Special Dampers with AE 40wt shock oil
- shocks located in the middle holes on the shock towers (took a guess here)
- just under 6mm ride height front/rear
- 2.5mm over ride height droop front
- 2mm over ride height droop rear
- no anti-roll bars (didn't have time to finish building them)
After describing the lack of steering (push) to Jochim, he advised I lower the front inside roll center from 3mm+1mm shims to 3mm shim and remove the .5mm front wheel spacers. This made a huge improvement but it still needs more steering. He continued to advise moving to 1C mounts. This car is for 17.5 blinky.
Are you saying the stock setup is already narrower?
What do you advise for a small, tight track with medium traction? We have lots of 90-180* turns.
#5687
#5689
I don't think they are testing any thing or they would of been testing it at the ETS,
#5692
I might be able to help you
Kit v5 setup is very narrow. What surface are you running on? I can't help if I don't know!!
http://www.rctech.net/forum/12360215-post29.html
Really? They'd test unknown parts at the most important race of the year? c'mon man, get with the program
#5693
Why would the most successful team on the WC level pull out of TC? I don't see it happening anytime soon. While the 417 V5 is .1-.2 sec down on pace in the hands of the RC elite, it is still more than capable in the hands of mere mortals. I'm sure Tamiya is developing their next ride as we speak, and it will probably look a lot like the Raceberry setup with a Tamiya twist. To assume that the sky is falling because an almost 3 year old design needs an update is just silly.
As far as Tamiyas not showing up in the stock standings at big races, that is an easy answer. They do not sponsor any stock drivers. How many guys will make the A-main in stock at the ROAR Nats, Snowbirds, or IIC that don't have some kind of chassis sponsorship? My bet is none, and if that did happen I can guarantee that they would have one before the event was over.
The sky is not falling!
#5694
If the Tamiya is so bad, and to be sure, it isn't
Where do all the other mfs fit in, that finished behind the BD7 & TRF
As far as I know, Tamiya do not pay drivers in the USA to race On Road, unlike other brands ?
You can't blame Pro racers for running inferior products to help pay the bills, if it keeps them in the game, and living the dream
#5695
There is also another issue, a car working well for Mod isnt necessarily the best for other classes.
My 417 with the solid motor mount was fantastic on foams, as you want a stiff car to do well (Well at our club). Now on to rubbers 17.5 and the v5 is really good, the corner speed is great against the Xrays which have a more planted rear. Last time out I was only 2 seconds off the 13.5FTD with my 17.5 (It was a technical layout).
In mod the car might be too much of a handful with that sort of rotation (It might have too much) The Raceberry seems to push the car more in a corner and it could have countered the eagerness of the 417v5 to rotate, making the drivers feel more at ease with the car and letting their thumbs do the business.
At our club, Tamiyas are increasing in their popularity as more people are seeing how well they perform.. or they might just like the shade of blue
#5696
It seems like the car wanting to over rotate is a trait of the 417 series. I race 17.5 rubber tire on carpet and getting the back end to calm down was the biggest challenge I had with my 417x. Once I started taking some steering out of the car, it settled down, but I have lost some corner speed with the setup I'm using. My current goal is to get the car to transition faster but still keep the rear planted.
#5697
I hope Tamiya does something interesting. I'm a lifelong fan. But their current offerings just aren't that interesting for people racing inside.
#5698
The car needs a tighter turning radius, it turns slowly at low speed compared to my TC6.1. It has a Savox 1251 servo, could that be the issue? My other cars have 1258's.
Team Powers 32 rubber tires.
Paragon Traction Compound (100% coverage).
Thanks for the help.
#5699
Its more the club based cars like the TA06ms that Tamiya does the out of the box thinking for.
I'm very tempted to try it as its different, and first reports are that its pretty capable.
#5700
I agree, that's why I am also a fan of Tamiya. The thing is I wonder if the TRF's will always be an evolution of the current cars as they dont want to alienate the conservative racing market, people might be hesitant to take a $500 punt on a totally radical car.
Unless they discover some giant leap in chassis or suspension technology I don't think they are going to abandon years of development for the next car.
