Tamiya TRF417
#4621
I didnt try the high droop values, but I assume that will make it even worse in lower traction conditions.
LEt me know what you find out, as we seem to battle the same issues.
#4622
will do. i'm right now trying to decide if i'm running the right cars int he right class lol. i've got a 417 as i mentioned in our stock class with spec tires, and i have a 416 with a grippy smokem chassis in our mod/open class and any tire i like. i think i might swap chassis around.
#4623
#4624
Anyone know what I can do to get rid of understeer? Im losing a lot of speed in corners due to using the brakes.
Also does anyone know if kawada or serpent spurs fit on the 417x?
#4625
Edit: also people often overlook camber as a tuning option, if you're running the usual 1.5/2 try 1.5 all around
I actually need to find a little more rear grip so I can lean on the outside rear tyre on power, if anyone has ideas I'd love to hear them
What chassis/surface/setup are you running? Tips above should help with understeer
#4626
Depends on your setup. Normally I try more rear droop, front shocks more upright, more ackerman spacers, front end more narrow (b/b), arm sweep, or shorter rear wheelbase.
I think they both fit but it's hard to adjust the mesh. Best to use panaracer, xenon, or tamiya
#4627
#4628
so i switched things up and moved my 417 to our open class and today ran it with sorex 28's and 24's with this setup
http://www.teamtrf.com/index.php/set...amp-futaba-cup
it works great for a bit, but then i develop snap oversteer. it seems to happen most mid corner on power. at first i was thinking i needed to find more rear grip, but then me and a bid started thinking about it, and i'm thinking more that i develop almost too much front grip cause the tires get warm.
thoughts, suggestions?
#4629
#4630
oh sorry, carpet. low-medium grip, depends on the day
#4631
This is an asphalt setup you posted, are you running the HPI blue springs too?
If so, try tamiya white front and tamiya blue rear. I also had good luck with yokomo pink, blue combination on carpet recently. A tad slower in lap times, but much easier to drive and faster 6 minute runs.
Also these yokomo springs generated less heat in the sorex 28 tires.
#4632
So for fun I took apart all four of my shocks today before I raced to see if they were full of air or not. Everyone of them had NO air in them at all.
I am however interested in checking out what the standard shocks are like on this car.
O well again another awesome day of racing with it. This car is awesome, nicely done Tamiya
#4633
edit: and no access to yok springs for now, but i've got i think the full range of tamiya ones
#4634
#4635
