Monster Horsepower Stock Tuning
Can anybody help? Ive just started to race stock class with my Pro 4 . My equipment reads as 3000 & 3300 batts, LRP quant pro speedo. I will be racing indoors on carpet. the track is small and twisty, also i need gearing for a large flowing track. Any idears
With a monster I'd suggest you start with a ratio of 7.3 - 7.5 for indoors and 5.8 - 6.0 outdoors and work from there
Originally posted by AdrianM
At S&N Trackside we ran 7.88:1 or 8:1 with Monster Stocks. It is a tight carpet tract that runs rubber tires. You are in the UK so you probably are running rubber on carpet. If you run foams at a starting diameter of 58-56mm then 7.3-7.5:1 is good.
yes because the final drive ratio gets higher so you need to lower the ratio.
Originally posted by The Black Kat
Are you trying to get him to burn his motors up?
I think he's talking about the 5.8-6.0 gearing. Not even if I was full throttle on a wide open track for the whole race would I think to go that far below 7.0 with a Monster Stock.
It really depends on the track and the type of layout you're on.
5.8-6.0 would be just about right for this track. kakegawa style
p.s. yeah, some of those dots are cars
edit: I re-read and mistyped something
Wow. I didn't notice that until I read your post.
just my .02 cents.
good luck and happy racing.
This is what happens to a Monster stock pro when you run with a gearing of 6
Been there, done that...
It all depends on your rollout, I run a 6.5 on a medium sized track. If I went to a large track I'd be running around a 6.0.
Stegger - I'd say start with a 24mm rollout and go from there.
rollout - (tire width in mm x 3.14) / Overall gear ratio
