Litemodz CVD
#361
Hi Guys
I drive for Litemodz, and have spent many hours helping with this excellent product, yes there has been a few issues, as do real car manufacturers when they put a new model out on the raod. There can only be so much testing you can do on any product, thats why car manufacturers have 'Recalls' as its us the public that are the inevitable guinee pigs, so is it for RC gear, not just these Litemodz CVS's. there have been issues with NG esc's and alike.
Jon and his very capable team have been working hard towards making this product a product for all aspects of RC, whether it be on road or off. He hasn't told anyone to go take a flying jump, quite the contrary, he has dealt with the issues, so I don't think you could ask more than that from any company, like some I could mention but won't.
You guys that have version 3, please hold fire untill you get the new internal C, clips. I have them in my car now and will be racing indoors on carpet 21mtrs by 12mtrs but on Sunday I will be racing on 32mtrs by 16mtrs so will give some feed back on Monday or before.
Cheers Malc TCCFM
Cheers Malc TCCFM
#362
I have spent some good time on calls and emails with Jon and his team about the issues. They have been receptive to the feedback and have been helpful. Look forward to getting the new parts.
#363
I'm a bit confused... I bought the very first version that came out, it tore itself apart sadly. LM realised they were faulty and replaced the front set... with what I thought was version 2. Are they now considered faulty as well?
I was going to put them in my new T3'11, but won't if they are causing issues as well. Also, does this mean the version 2 will be getting replaced, or do I need to purchase the new version 3?
Also with the rears I have, which are still the version 1, they have formed quite a bit of slack between the shaft, and the coupling. Is this fixable in anyway?
I have to say though... the racers I have run with them in were fantastic, so much more planted throughout a corner. A great hop-up part, with real performance gains.
#364
Correct me if I am wrong but are the slots on the dogbone parallel to each other as it looks this way in the photo.
In my opinion if they are parallel to each other [ ] then when the are at an angle to the axle then the balls must be pushed on an increasing diameter.
Should the slots on the bone be machined like ( ) then the diameter is constant through out the angle relative to the axle.
The axle can be machined parallel but the bone must be macined on the same radius to maintain the diameter that the balls pivot on.
#365
Makes sense
Jon comments please? (I trully am curious)
#366
Hello Gav
The V2 has a redesigned axle which is okay. The issue we had was with the clip hence a revised clip is on its way to all customers as a retro fit. The V2 simply comes now with the revised clips as do the rebuild kits.
The issues with the CVS clips are due to a few reasons. The main reason is due to servo savers and the lack of physical lock stops on cars means that at full lock the clip was being deformed by the shaft as the steering angle goes beyond the natural limit of the car and the shafts. Due to ackerman and the flexible nature of the wishbones and c hubs the steering angle has a tendancy in impact (whether hard or not) to move to about 45 degress to the shaft. At full lock the CVS does have about 4-5 degress extra articulation which means that under all theoretical conditions a clip would not be necessary at all but in the real world things are different.
With our standard CVA’s at any angle beyond the 34-35 degrees the shaft is in contact with the axle. On the CVS the shaft is in contact with the clip which has a degree of “springiness” which can cause deformation. The new round clip is better at withstanding load from over lock.
The clip coming off is pretty much the same as a pin coming out on a standard CVD even if you thread locked it etc.. By that I mean the load applied to it is the same. The new round wire clip stops deformation and transfers more load through to the axle and as a result will be more able to withstand abnormal loads.
#367
The balls are pushed on an increasing diameter yes. However, if the angles were constant relative to the axle then the unit would not work provide constant velocity. If you would like to PM me I can explain in more detail
#368
So the balls are increasing in their diameter, this must increase the friction inside the axle, as the diameter is governed by the inside diameter of the axle itself.
To much clearence to allow for the increasing diameter of the ballraced balls will result in excessive play or movement in the parallel position.
If the axle pivots off the centre datum on the grooved end of the bone and the grooves are machined on a radius the same it must be constant.
How can that not provide constant velocity?
Sorry your comment is "if the angles were constant relative to the axle then the unit would not provide constant velocity".
To me it seems that under large angles or hard hits that put large angles on the bone to axle angle, therefore increasing the diameter of the ballraced drive bearing the only place they are going to be able to move is out. Taking the weakest part which is the retaining ring with it.
It seems the only way to make them foolproof is to radius the grooves on the end of the bone so as to eliminate the bearing movement on that increasing diameter.
In simple what is the diameter of a 6mm circle and what is the corner to corner measurment of a 6mm square box?
One increases in size when turned on its centre the other does not.
#369
Just to make it quite plain, I'm no tech.guy, I just come up with the daft ideas. I leave that sort of stuff to those who know what they are talking about. This is the reply I've just got from them.
The grooves on the ball end of the shaft indeed have radii but simply moving the intermediate component at the same rate as the shaft inclination does NOT provide constant velocity. The intermediate section has to be controlled in a certain manner. Move over the intermediate cage design prohibits movement towards the outer face of the axle in the horizontal plane. The picture on RCTech and red RC is not quite the item. I may add that this is not a copy of the Birfield Rzeppa pot type joint you are eluding to.
#370
#371
My basis was purely from looking at the components that are in the linked picture and the corresponding post.
The comments that you make are contradictory and your request that I PM you for a further explination are down played with this post you have just replied with.
As you claim now you are no tech guy.
My assumptions were condusive to finding a solution.
From looking at the pictures of the components I could see the potenetial issues that may have been arising from the design of those components.
The radius in the grooves to me was one way to allieviate the problem of the retaining rings being pushed out by the bearing pushing against them.
Good luck square things dont go to well in round holes.
#373
is V3 needs new C clips or are they safe to use?
cheers
cheers
#374
Sometimes people can be to sensitive untill they have re-read what was actually posted as a comment, myself included in that assesment.
I know many people who have used these drive shafts and like them just not the reliability that they have. Good concept just not there quite yet.
#375
I am glad that you altered your post as I don't feel I was bashing litemodz at all, just giving my observation and response to replies that I have read.
By the way can anyone tell me what option for these would fit the Losi Type R?
