Losi XXX-S
Excuses excuses.
The Evicerator
Hmmmm...I'm pretty sure I gave one of those shock towers away... and I'm pretty certain it was you
R/C Tech Elite Member
You wouldn't happen to know when Losi is gonna put the new ballcups up for sale sepearatly do you, I want to replace mine, but since replacing ballcups sucks, I'd rather just put the new ones on now.
Randy Caster where did u get those red nuts for the ballstud on the shock tower?
Fastener Express is where I get all of my red screws washers and nuts.
can u give me a link please?
http://www.fastener-express.com/inde...OD&ProdID=1763
$17 for the kit bu $5.95 fror shipping!?!?!?!? It's freaking 8 oz worth of screws!!! And I though Ebay was the only place that reamed you on shipping.
Hey Guys,
How are you dealing with the slop factor of the xxx-s?
Washers between arms and hubs?
Also, do you know if the team associsated ball cups for the tc-3 will fit on the graphite plus?
Thanks in advance;
Adrian
Thanks in advance;
Adrian
Originally posted by adrian
Hey Guys,
Thanks in advance;
Adrian
Hey Guys,
Thanks in advance;
Adrian
Use thin motor shims to shim the arm slop, .003, .005, .010 shims should be the ones you use. The losi ball cups should be fine although I would think the AE ones would fit if you really wanted to use them. If you can find them on the shelves the new losi white ball cups are slop free and arent overly tight.
if anyone here has experience with using rc10 ball cups please tell me!
Cheers
Adrian
james-the speedworld track was pretty good today, pretty tough at first...I see mod and 19turn time to be pretty close...
my car didnt run all that great in the heats, i was off pace big time, then goss took a look at it and just changed the ride height and checked droop, and wow it worked good......unless he did some trick to it i dont know of...
Dal, they just posted a bunch of signups on the nats, you're not on the list ..might want to email them & make sure they got your form??
