Tamiya FF03
#1173
Go Lakers! errr I mean Go Cuda!
I also received some bodies...hmmm which one should I try first:
- Volvo 850: shoebox on wheels
- Lancia Delta Integrale: even more of a box on wheels (need trim front lip of the body and run no bumper to make it fit )
- Subaru Cusco: kinda like a sedan...HUGE wing....sorta cheater lol
- Audi A4 DTM: see above
#1174
I had that same issue all day yesterday. Did you find a cause? The plastic blade on the drive shaft snapped off as well. I can only think the screw worked out when I got tapped and hit into the wall, screw came out and then the drive shaft was now to loose causing the blade to snap off.
#1179
Sweet Lancer
#1181
Got some more FWD bodies in, including a couple Tamiya Beams Integras and HPI Civics. Still trying to source more of those Focus bodies...
#1182
#1183
all nice Rally Bodies.
#1184
Hey guys, just had a quick question.
According to Tamiya USA, "All bodies must use the wings that are supplied in the kit. Mixing and matching ABS plastic wings between different bodies is not allowed. Part number 53470 (Lightweight Wing) and 53604 (Racing Wing Set) or any future optional wing set is allowed to be used for any sedan or sports car body in certain classes".
So essentially any 'legal' body for an FF03 is allowed to use these optional wings correct? Is this what most are doing? I have seen some kit ABS wings that are awfully small and would like to run a different wing for some more rear down force.
