Hot Bodies TCX
#4156
Guys, I found out that there is a play in the shock pistons. This is fixed by putting one 3x5x0.2 washer on top of the piston and then putting on the E-clip.
Regards,
Terry
Regards,
Terry
#4157
Korey said it's important not to make it so tight that the piston can't rotate on the shock shaft, but I don't know the reason for that. The TC6 shocks seem to clamp the piston completely.
-Mike
#4158
Regards,
Terry
#4159
Spec-R shafts for TCX
I have question regarding changing shafts from aluminium to steel ones. Recently before HB released steel shafts I have switched to Spec-r. Now I want to try DCJ shafts from Spec-R, but they dont produce it. The question is if it will work if I put Roche spool for TCX that come with outdrives for Yokomo or tamya and buy spec-r v2 shafts for Yokomo BD5 will it fit on my tcx with new 3holes arms and standart C-Hubs? Thank for advice.
#4161
#4162
Hot bodies
Any benefits 2 running the hd aluminum I race on asphalt
#4163
#4164
Hello,
A friend got a tcx with a spec R gear diff. Can he use xray blade on it ?
#4165
#4166
#4167
#4168
That's why these have been made.. Solid Axle Long Cup Part.Nr. 68796. Sorry, can't post direct link.
#4170
Yes I know it. but they are very weak. I have used it before but it wears down in 10-20 runs. I have changed it in every event. I am driving 17.5 motor so it has not so much power. I saw that people who runs roche never changes it at all it does not wear so fast.
