Hot Bodies TCX
Old 01-11-2012, 07:02 AM
  #4021
Originally Posted by Yokomo_Ant3
By the look of the stickers on his car, a TCX won the 17.5 class at the DHI cup His car looked very good on track aswell, be keen to know what chassis he used on the car.
Steffen was racing the TCX, he used my lipo chassis, same chassis as seen on the cars of Freddy Südhoff and Dominik Fleischmann and some other HB guys
Regards
Marcel
Marcel is offline
Old 01-11-2012, 11:13 AM
  #4022
Originally Posted by 008-Racer
What brand of spur gears are you all using
I run in 13.5 Blinky and need to gear at around 4.5 - 5.5?
Any help much appreciated
You don't say what pitch your using but I run an Xray 48 pitch 84 tooth. The only issue is that only 2 screw holes line up, but that's not been a problem for me over the last year.
markrobinson is offline
Old 01-11-2012, 12:42 PM
  #4023
Barry_Hughes's Avatar
Any other brands?
I am based in the UK and need some fairly urgently!
RW Spurs fit OK
Barry_Hughes is offline
Old 01-11-2012, 01:50 PM
  #4024
AGNO's Avatar
I use the RW spur, mod 48 77/33 = 4,55
AGNO is offline
Old 01-11-2012, 11:48 PM
  #4025
Thanks for all the help on the spur gear advice
008-Racer is online now
Old 01-13-2012, 08:45 AM
  #4026
Coldn's Avatar
hello guys, I have problems with my CVD, I do not know why but even putting a lock liquid in the screw, the pin shaft always out and broke my stering block, I searched but did not find any solution on the internet, but I found for TRF417, as in the photo below, do you know if there is something like this for the TCX
Coldn is offline
Old 01-13-2012, 09:00 AM
  #4027
Trader Rating: 19 (100%+)
The tamiya stub axle and coupler set is a direct replacement for the HB parts. Just use the HB dogbone and you will be fine.
Advil is offline
Old 01-13-2012, 09:09 AM
  #4028
AGNO's Avatar
These, http://www.hpieurope.com/piw.php?lang=en&partNo=68759
# 68759 UNIVERSAL AXLE PIN COVER (2PCS)
fit over the CVD and the pin shaft will not go out anymore, and the screw is not necessary.
AGNO is offline
Old 01-13-2012, 09:11 AM
  #4029
olhipster1's Avatar
Trader Rating: 102 (100%+)
Attachment 861552
+1
best option are the Pin holders.
using the screw compresses the screw to on side...always best to let the pin float in it's position.
I've been using the following:
Top ti covers...but others will fit also.
HB axle
Yokomo bones
Yokomo spool cups (steel)
this setup is virtually chatter free.
and I found to be the cheapest route
olhipster1 is offline
Old 01-13-2012, 09:53 AM
  #4030
Coldn's Avatar
Attachment 861552
thank you AGNO, I realy dont knew about this. I will buy one for me!!
Coldn is offline
Old 01-13-2012, 10:00 AM
  #4031
Coldn's Avatar
Does Anybody used thermal retractable (Shrink Tube) to cover the axle pin?
Coldn is offline
Old 01-13-2012, 10:18 AM
  #4032
olhipster1's Avatar
I have used it before...
you have use the right stuff....super flex and strong (usually has a glossy finish)
has to be cut perfect as to not interfere with axle movement.
but I still prefer the axle covers above all.
Old 01-13-2012, 10:26 AM
  #4033
Coldn's Avatar
uhun, it's only to use until the HB cover arrived here. hehehe
Coldn is offline
Old 01-13-2012, 10:31 AM
  #4034
olhipster1's Avatar
The TOP axles covers fit perfectly....if can get them in Brazil.
Old 01-13-2012, 10:37 AM
  #4035
AGNO's Avatar
Yes, also axle pin cover TOP, fit well
AGNO is offline
