Tamiya TB-Evolution IV
#586
Originally posted by KREATOR1
So if the 1 way works on evo4, maybe the evo4 bevel can fit in to
the evo3
im out of evo3 bevel
the evo3
#587
Re: Re: Re: Re: a few small things
Originally posted by The Black Kat
Evo3's are 3mm too I belive
#588
Originally posted by JDM_DOHC_SiR
also the EVO3 derlin diff is a direct drop in to the EVO4....
#589
Originally posted by EVOtech
Are we really sure about that? I never thought there would be any real commonality as its a Tamiya/Tech joint design, like the 415.
#590
evo4 on order should have it soon hopefully.
i cant wait the 415 working well and this car is gona be a blinda methinks.
#592
Originally posted by trf racer
the evo4 use evo3 outdrives and so the trf 415 can also use evo3 outdrives in the back.
Standard diff needed for the front for indoor slippery things, so if they have, not buying one!
#593
Originally posted by HPZ
Just wondering what size are the hex screws on the evo4? i only have the standard evo3.
#595
So i will be using a 3mm Hex driver right?
#596
So, what about the front then? Have they done the dirty?
the 415 can have diffs built but you need some yokomo parts which is listed in the 415 thread a few pages back.
then all you need is the solid middle pully.
#597
the evo4 is pure tamiya
#599
#600
