SD glitching
SD glitching
My Yokomo SD is glitching, but its only the throttle. Does anyone know what its like that, or how to fixed?
Originally posted by eeyan
Check your motor... are they clean? Probably a bad brush, Comm?Usually glitching affects both channels(steering and throttle)...
ill check my brush, tho the last time they still had alot in em
Read my thread first.
Cut the comm $5
Brushes=3.00
also make sure there is no bare wire on the ariel. I had this problem as it touched the top deck and caused glitching and that was only on the throttle.
Sleighty
Sleighty
If you're using a motor with a "capacitor board" on the endbell (e.g. Trinity Monster), solder a set of capacitors on properly.
Im running the trinity Kobal 13x2
Imma try switching motors and see if it still glitches
Whoa!! What a coincidence...
I just posted a question about something that should help.
http://cgi.ebay.com/ws/eBayISAPI.dll...tem=3181319214
Lots of detail.
Lots of detail.
My steering isnt affectted by the glitching tho, only the throttle
Even my throttle was glitching when I tried to accelerate. I guess the batteries could not supply the power quickly enough.
Sleighty
Sleighty
