Schumacher Corner
Originally Posted by Roberto Falcon
I dont think you guys can out beat me , I had
Pro 4
3-TC4's
2-415ms
3-RDX's
3-Mi2's
2-xxx-s
JRX-S
FK04
FK05
T2(never ran)
and now a Mi2EC...
and thats from last year alone till now
Pro 4
3-TC4's
2-415ms
3-RDX's
3-Mi2's
2-xxx-s
JRX-S
FK04
FK05
T2(never ran)
and now a Mi2EC...
So true. Roro give's hoo ha's for touring cars.
Is it nessacery to run the rear shock tower spacer?
Originally Posted by LeadFoot
I need some setup help for a very technical track on carpet using foams.
I have the older Mi2 w/the kit shocks using Xray springs (I never got the the new shocks and springs). I am running stock and 19T w/3300 batteries. I do have the older Teemu chassis but I thought I would need more flex and movement for this track so I have the standard chassis on
The track is 120 x 60 ft but the setup is all turns. Everything is a shortshoot to then next turn. There is no straight that is more than 8 to 10 ft before you have to turn left or right.
I want to be on power except at half throttle around all the turns but I cannot seem to get the on power steering. I am pushing.
Any setups or advice on things to try
The shop is speedzonerc.com in Rocky Hill, CT and since the shop keeper has shuie kits and parts on the shelf I want to make this track work for me.
Originally Posted by AdrianM
The rear tower spacer is there to make the shocks vertical when viewed from the side at the rear most wheelbase settings. If you are running a shorter wheelbase you may not have to run it. Making the shicks vertical eliminates unnecessary side loads between the piston shaft and seals/bushings and makes the shocks have less friction during movement.
hey,adrian,what setup are you and paul running on aspalt,im going to that indoor aspalt track in fredrick,maryland to do some setup testing.
oh,and as you know,i had setup issues at snowbirds,but now my car is soooo freakin dialed,it's insane i've won 8 out of the last nine races and i'm the first on to hit 25 lap,now if cuffs would just come back so i could show him how to wheel a stock car
whats up ,reggie ,when you comin back to rosewood?sya
I think you better look back at the eXpress race results, 25 laps were hit back in Dec. by a few guys.... If you wanted to show Cuffs how to wheel why weren't you in Maryland this weekend?
You may also want to look back thru the results 8 out of 9 is not what I see.....
Paul ended up dropping 5wt front and rear to 25wt (F) and 30wt (R) since it was cold the last time we raced.
Justin, is it possible I could borrow that checkpoint can you have for the race in california? I wouldn't need the arm, just the can.
Thanks Brandon! It's amazing how so many haters monitor the Schumacher boards
Keep up the good work Justin
hello
hello people new member to the forum and also a fellow schumacher racer schuamcher rules
ha,ha anthony, come on to rosewood and let me take you to school and i know cuffs hit 25 laps, but that was at the xpress and the track was faster.sure brandon you can use the cheakpoint can,i'll have it with me this weekend.I'll run mod with ya if you have a motor i can use.it's time to let george and jimmy win in stock.hopefully me and brandon will put on a show in mod,28 laps
