Schumacher Corner
#6332
Originally posted by AN
Adrian can you post or e-mail ([email protected]) the PW base setup for asphalt tracks (rubber tiers)?
/AN
/AN
I have only run the MI2 with foam tires so far and have been very happy, although i have a rubber tire race coming up (i have little experience with rubber). the track is medium with a few technical surfaces, outdoor asphalt, mod class, there is a control tire Sorex 36 with sorex C insert.
Please advise if the PW base is appropriate or if there is something else that would work well.
Thanks in advance
#6333
#6336
AdrianM (or anyone else with good suggestions)..
Was hoping to get the new MI2 today..hasn't come in yet, but may still come in the afternoon delivery. Are there any special building suggestions I should think about while putting it together. From what yout old me on the phone that I can remember...drop of oil on screws to keep them from seizing, and follow the setup sheet you're sending to the letter.
Any others??
Mark
Any others??
Mark
#6337
New toy arrived...know what I'll be doing this evening...
#6338
Mark, No there aren't any special tricks that aren't mentioned in the manual/team tips sheet. All you need to do is take some time, and make sure that you are resting the car on a flat surface when you are tightening the chassis components. Just make sure everything seems right, and chances are it will be.
#6340
Cool...thanks guys. Can't wait to get to the build...
#6342
Ya you wont be needing the tensioners
Lossen up the rear diff they come built a little tight
I suggest going with a spool also you wont be dissapointed
#6343
hi guys i jsut built my mi2 today and am quite pleased with it, the drivetrain is free as hell. One thing that i doint like and i dont know if it is only me but the c/s screws are sitting very proud underneath the chassis and i have tightend them as far as i would like without putting to much strain on them. Is this normal and if not what should i do
#6344
