Schumacher Corner
#286
Location: Beautiful Downtown L.A. Where the sky is always on fire and the grass is always brown
JesseT - Good, I left it out! THANKS!!!
#287
It should be used only if the screw comes out from the bottom side of your chassis plate. It will not happen on std. Axis2. I'm glad I could assist.
#288
mini/jesse, that is true, providing that you are not using the A2 carbon top 3 pc deck. If this is the case and you have both long posts, it then goes on the RHS, between c clip and bearing.
#289
Say Guys...any update on the expected delivery date of the Mission...can't wait to get mine...last I heard we were talking late Oct or early Nov... but it sounds like they are still testing preproduction, so is that delaying he production/distribution...
#290
Most of the final tweeking is on the chassis, which doesn't take very long to make once the pattern has been determined. The things that take time are the molded piece, which (as I understand) are all complete (or almost complete). Release date is still Nov 1 (26 days and counting)
#291
can't wait....
#292
everything I've seen indicated they had the chassis worked out, but nothing on the new drive train...major changes there...just thinking out loud
#293
markg....racerX was spot on. The drivetrain was assembled this week and will be run all next week as preproduction testing. Preproduction means the final molded car to check parts fitting, strength and handling in production form before final release and prototype is the hand made car (5 or 6 versons) used in early testing.
The car is on schedule for the Nov. 1st release date.
#295
Anyone,
I'm considering to get a used Axis 2. Is this a good car? Which part of the car is prone to breakage or needs beefing up? What's the difference between this and the Axis 1? What's so good about it?
Thanks,
Ivan
Thanks,
Ivan
#296
Ivan:
yes, great car!
I havent broken one thing, but I would recommend the aluminum motor mount and front lower aluminum bulkhead
it's just a great car!
yes, great car!
#297
ivan? is that you?
anyway, the main differences are the double thick chassis and of course the turnbuckle top deck which is said to eliminate tweak. most else is the same. some switch back to the rigid top for high grip applications.
#298
hey guys i just installed the tungsten carbide diff balls and i was wondering how many turns past when the balls just start to grab do you run your diffs. what does schumacher call for like 1 5/8 past? with tc balls, can i back off and how much?
#300
Corey - Tell me more.. and how much for everything?
