Schumacher Corner >
Schumacher Corner
Schumacher Corner
Old 11-22-2007, 08:23 PM
  #23326
AdrianM's Avatar
Thumbs up Head's up on diff rings
I seems Schumacher has improved the U2408 non indexed diff rings. I just got 2 pairs from Schu USA and it seems that they are ground to size now. The old ones were stamped and you could see a rounded side and a sharp side. They used to fit loosely on the outdrives.
The latest U2408 rings are awesome. I sanding them may no longer be necessary. They also fit very precisely on my Mi3 outdrives.
Big props to Schumacher for doing this small but very important improvement!
AdrianM is offline
Old 11-22-2007, 08:31 PM
  #23327
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by abailey21
I dont know yet....I'm becoming more and more booked up by the minute
Ill be at work after 3:00PM (hint hint!!)
Marcos.J is offline
Old 11-22-2007, 08:32 PM
  #23328
Super Moderator
Marcos.J's Avatar
Originally Posted by IslandBwoy
Are you guys sure there will be a foam stock class? If so, that sounds like a plan.
However, whats up with schumacherpitspace? I cant get to it. Can someone shoot me wylens setup?
Thanks,
R
if not there will be a 10.5 class
Marcos.J is offline
  #23329
JayBee's Avatar
Trader Rating: 31 (100%+)
That's old news Adrian!!!
JayBee is offline
Old 11-23-2007, 12:10 AM
  #23330
R/C Tech Elite Member
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Rumor has it that Goetz is dialed at Cleveland right now...
Randy Caster is offline
Old 11-23-2007, 05:43 AM
  #23331
IslandBwoy's Avatar
Trying not to bring 3 cars our there. Planning on 1/12 and stock foam or rubber which would be my EC. If I run 10.5 I would need to bring my mi3 too :-(
IslandBwoy is offline
Old 11-23-2007, 06:13 AM
  #23332
Sigearhead's Avatar
Trader Rating: 74 (100%+)
Goetz' is always dialed. His cars always looks like they're on rails.
Sigearhead is offline
Old 11-23-2007, 06:53 AM
  #23333
abailey21's Avatar
Trader Rating: 37 (100%+)
I have a set at the house i'll drop by shortly after 3
abailey21 is offline
Old 11-23-2007, 07:36 AM
  #23334
Super Moderator
Marcos.J's Avatar
you are the man!!! ill pm you my cell#
Marcos.J is offline
Old 11-23-2007, 07:37 AM
  #23335
Super Moderator
Marcos.J's Avatar
im sure that 3rd car takes alot of room
Marcos.J is offline
Old 11-23-2007, 09:24 AM
  #23336
AdrianM's Avatar
I know that Jason and I will be running TC Foam Stock. I heard Roberto Falcon from Orlando is too.
I put McGoo's setup on my car down to the new 1deg alloy rear hubs.
Hey, McGoo...what cetner track rod are you running. Narrow, Mid or Wide and Short, Med. or Long?
I am starting my tires just under 58mm..is that ok or too big still?
AdrianM is offline
Old 11-23-2007, 09:33 AM
  #23337
JayBee's Avatar
Hey McGoo, what would you change with 10.5 power strapped in?
JayBee is offline
Old 11-23-2007, 09:45 AM
  #23338
Nothing.
Maybe a tick higher spring rate, but thats it. And the gearing of course.
Jan Larsen is offline
Old 11-23-2007, 09:49 AM
  #23339
Adrian -
I believe he's running the kit track rod.
Chris
ckearns is offline
Old 11-23-2007, 12:10 PM
  #23340
Mr. McGoo's Avatar
Trader Rating: 23 (100%+)
I am just running the stock trackrod (med/med)...it feels the smoothest of them all. I haven't tried any of the wide trackrods, but i would like to try here pretty soon....
As for tires, I start my club racing tired at about 58.25. I usually try to get one practice run in with them to scrub them in and that gets me right around 58. Just be aware the car will be a lil too twitchy and feel tippy with the 58's. The car is perfect by the end of the race day when they are around the 56.5-57mm mark.
@ JB - I have found that with 10.5 the setup might feel a bit pushy. I ended up putting some initial brake in my speedo and a touch in my radio to help the car from rolling too much through the corners. I have been running 5* tamale blocks the past few weeks, but I still like the extra initial steering you get with the 6*. If your car is feeling pushy entry, try getting more caster, if it is pushing mid/apex/exit - you might want to try the extra caster and go up on springs to compensate for the car being more aggressive and diving faster.....
Mr. McGoo is offline
