Schumacher Corner
yeah, the stiff 2.5mm top deck works great! my club has med-low traction and the thick top deck is just right.....
just out of interest what length have you set your shocks to when using the lowered towers? or has anyone else got a starting point for shock length when using them.....
Stevie b from the cheshire forum
I dont know stevie, ive got some here to try and will probably just shave a little off the bottom ballcups to get them the right length, just hoping someone can give us a clue what the right length might be! Going to investigate further tomorrow and see what i come up with!
A Lot of that will depend on tyre diameter - and Colin, something tells me you're unlikely to take tyres out of the box and true them right down
I was going to true mine down to 58mm, any suggestions????
hi guys
Is there any way to bring back to normal The Tweaked Chassis???
I just Take it out from car and Put it on a flat surface and put another flat weight on top does it helps or do I have to go for a new chassis ??? If So is there any one tried Stiff chassis I'm gonna race on Carpet most of the time
Thanx in advanced...
hi guys
For carpet, I run the 2mm chassis and the extra stiff top deck. We have med/high bite carpet.
I have the lowered towers on my car. Front shocks at 60.5mm w/ associated shock bottoms and I cut off about 3/16" off the top of the ball cup. Rear shocks at 61mm w/ associated shock bottoms. I always start my tires at 58mm's. I use 4.5mm ride hieght.
Alright guys - I am working with Larry from Team Tamale on having him make us up some front C-hubs - namely in 4*, 5*, & 6*. He has been making stuff for the Xray cars for quite some time. He uses the best aluminum available - the same stuff that is used on Boeing planes.
you can check out his website at www.teamtamale.com
His normal rates on a pair of chubs are $50 + shipping. I am just trying to get a head count on how many people would be interested.
just post here or shoot me a PM on what degree you would be interested in.
mcgoo
mcgoo
R/C Tech Elite Member
hi guys
If you can't get your car completely flat, chances are you bent a bulkhead, then you gotta take each one to a flat board to see which are causing the bend in your chassis and replace it/them.
If you've set the tweak on the car with a bent chassis you'll want to re-tweak it and set the droop again before you hit the track, otherwise even though the chassis is flat, it will drive tweaked.
lol. In all seroiusness, i do have some carpet towers and at some point will have a play with them.
