Schumacher Corner
#1966
Regional Moderator
Hey guys. I tried running my rear diff slightly looser than it came out of the box. The car handle great after this. Problem is that once I loosened it, the diff would proceed to completely loosen itself until the diff was completely loose. A budy of mine I was practicing with did the same thing to his diff, but his didn't loosen. The only difference is that he said that after he loosened his diff, he went back and tightened down the locking grub screw on the other side down. I didn't do this. Is this why mine kept loosening up on me instead of holding the settings? Should I go back and tighten down that locking grub screw after I loosen the diff?
#1967
Darkseid: you must lock that screw also if u dun want the diff to get loose
#1968
Regional Moderator
Jean Alesi: Yeah, thats kinda what we figured the problem was with my diff. So the next time I decide to loosen the rear diff up a little, I'll remember to tighten down the locking screw as well.
I just have to remember "loosen diff screw, tighten locking screw"
#1969
Trader Rating: 32 (100%+)
Ottoman...is it on power commin out of the corners or off power coasting. If its on power you can try standing the rear shocks up one hole in the rear as that will keep more weight on the front under power. If that does not work try moving the lower arm back this will reduce castor more and give more weight bais to the front end. I like the car with the least amount of castor possible, I even went so far as to grind the upper bulk head so I can take even more out. I might try rear arms in the front as that should take some of the castor out of the pivot ball, but you need to make a crash stop on the arm so you will not break the axel in a crash. I will try this next weekend and let you know.
Cornerspeed....Im not running stock shock shafts or pistons and mine dont hit the top intill full compression, and I still dont think that you will ever see that on the track. I did see that when I ran the stock parts but I still never really felt that you would get into that range of motion on the track.
#1970
Here is my Mission
I used the tyres that came with till they came apart they were perfect for a rookie.
#1971
Here is my Mission
I know the purple wheels got to go.
#1972
KevinK- raising the roll centers f/r with the that Fireblade part, is a little fuzzy to me?What exactly does it do to the cars handling charecteristics that the car doesnt have already! ALso Kevin, not critiking your setup, but why do you use Losi springs for running outdoors?
#1973
Corey.....You only use the Fireblade parts on the front of the car. In the rear you can use washers under the stock pices to raise the RC. This mod gives the car more mid corner and exit steering and makes the car roll more, you can use soft springs and not fear too much of the car grip flipping. I like the Losi springs over all springs because they offer the best selection and feel the best on the track. I do run Losi springs outside as well but the set up I posted was for carpet on rubber tires. Last weekend I ran Losi yellow and pink springs on my car outside but it was 45 deg out. I just feel the Losi springs work the best, I have tried all the springs on the market and they just suite my driving style the best and its easy to get ride hight out of them. Also they dont jump 5 to 10 lbs untill you get realy stiff like some springs do.
#1975
Mission blank setup sheet
SirSpeedy
does it have to be JPEG? Culd it it be a "WORD" doc? I have a Mission setup sheet in JPEG format it is to large to post please email me.
RC
RC
#1976
Any body have any setup suggestions for switching my Mission setup from road course to a oval? In addition, anybody’s opinion on oneways. Thanks!
RC
RC
#1977
The roll center mod on the front actually makes it the same as the rear. If you want more steering, high roll center front, low roll center in rear, or basically leave the rear alone.
#1978
Is the mission good for stock. I know its good for mod but not stock. I race a xxx-s now and was wondering if it woudl be better then the xxx-s?
#1979
I'm currently running an Axis2 in Stock here in Phoenix, and it handles fantastic...I can't imagine the Mission not handling better, plus it's got a more efficient drive train. As soon as I'm able (Next month or so) I'll pick myself up a Mission too...I had a buddy of mine who runs a XXXS drive my Axis2, and he LOVES it...so much so that he borrowed my backup car!
Ron
Ron
